Question about Sony ICD-P320 Digital Voice Recorder
Installing software originally for windows 98 to windows XPI have tried to install my ICD-BP100 recorder to my new laptop via the usb but the software installation says it is not compatable with windows XP and recommends I discontinue installing. Is there anything I can do? I have downloaded the new version of digital voice editor.
  • maggie_bunti Nov 22, 2008
    I have downloaded the new version of digital voice editor for my ICD-BP100 and playerpluginsetuo129.Exe but my files from my recorder are still not being displayed in digital voice editor
    Scholar:
  • 181 Answers
Just needs reinstallation.uninstall the the driver which u have loaded and then reinstall it again.it also stops displaying if not got detected or if some of the files in your new xp os system is blocking the software.
for detailed help from point to point u can just check out the link in my next comment
Posted on Nov 22, 2008
    Sergeant:
  • 276 Answers
Connecting the IC Recorder to Your Computer -------------- Connect the IC recorder to the USB connector of your computer using the supplied USB cable. ----------- Note Be sure to install the “Digital Voice Editor” Software before connecting the IC recorder to your computer. ------------------- USB connecting cable can be connected or disconnected when the IC recorder and the computer are turned on or off. The IC recorder is recognized by the computer as soon as the cable is connected, enabling you to proceed with the operation. --------------------------------- Notes • Do not connect more than two USB devices to your computer. Normal operation will not be guaranteed. • Use of this IC recorder with a USB hub or a USB extension cable is not guaranteed. • A malfunction may occur depending on the USB devices connected at any one time. • Check the remaining battery power of the IC recorder (more than one segment of the battery indicator should be on) before connecting the IC recorder to the computer. If the batteries are exhausted, communication between the IC recorder and the computer may not succeed. • We recommend you disconnect the cable from the computer when you do not use the Digital Voice Editor. ---------------- Starting Up the Digital Voice Editor Software 1 Start up Windows. 2 Click [Start], and select [Programs], [Sony Digital Voice Editor] and then [Digital Voice Editor]. The Digital Voice Editor Software starts up and the main window (page 50) appears. The data in the IC recorder is loaded to the computer and the message folders and message files are displayed in the IC RECORDER message window. When the IC recorder is disconnected, no folders or messages are displayed in the IC RECORDER message window. Connect the IC recorder and proceed to the next step. 3 If nothing is displayed in the IC RECORDER message window , click the [Connect] button on the lower left side of the window (page 50). The messages in the IC recorder are loaded to the computer and displayed on the IC RECORDER message window. Notes • If no messages are loaded and an error message is displayed after you click [Connect], the IC recorder is not securely connected. Check the connection. • The number of folders in the IC recorder message window differs depending on the type of IC recorder you are connecting. To quit the Software Click the [X] button on the upper right side of the window or Select [Quit] from the [File] menu.
  • smarttech Nov 22, 2008
    Toolbar
    The toolbar contains the buttons for frequently used menu command
    tasks, providing a quick way to accomplish the tasks. See the online
    Help files.
    2 Menu commands
    Enable you to execute various commands. See the online Help files.
    3 “PC” message window
    The list of messages stored in your computer's hard disk is displayed.
    4 “IC RECORDER” message window
    The list of messages in the IC recorder is displayed.
    5 [Connect] , [Mail], [Voice Recognition] buttons
    See the online Help files for details.
    6 Player window
    Contains the buttons or sliders to control the playback operations of a
    message. The information of the message being played back is
    displayed. See the online Help files for details.
    7 Status bar
    Displays the current status of the software operation.
    Saving Messages to the Computer
    You can save the messages as sound files on your computer’s hard disk.
    There are two ways of saving messages:
    • Saving by specifying the file type and file name
    • Saving as DVF files by a drag-and-drop operation
    This manual explains the latter. To save by specifying the file name and
    file type, refer to the online Help files.
    Notes
    • The following characters cannot be used in a file name: \ / : * ? ” < > |
    • When a message with the same file name exists, the dialog box appears to ask
    you if you wish to replace the existing file. If you wish to replace the file, click
    [Yes]. If you wish to change the file name, click [No].
    • When a message is saved to the computer, its alarm setting will be cancelled.
    Saving messages one by one
    1 Click to select the message you wish to save from the “IC
    RECORDER” message window.
    To select multiple messages, press and hold down the Shift key as you
    click the first and last messages in a consecutive group or the Ctrl key
    as you click each message separately.
    2 Drag the message and drop it in the “PC” message window.
    The message is saved as a DVF file. The file name is labelled
    automatically.
    Saving the entire messages in a folder at one time
    You can save the entire messages in a message folder (A, B or C) at one
    time as one folder.
    1 Click to select the message folder you wish to save from the
    “IC RECORDER” message window.
    2 Drag the message folder and drop it in the ”PC“ message
    window.
    The messages in the message folder are saved as DVF files. The file
    names are labelled automatically.
    Saving all message folders at one time
    1 Click the “IC RECORDER” message window.
    2 Click (Save All) on the toolbar.
    The dialog box appears to request you to specify the destination to
    which the folders are to be saved.
    3 Specify the destination to which the folders are to be saved in
    the [Save in ] box and the file type to save the contained
    message files in the [Save as type] box.
    The folder and file names within the saved folders are automatically
    named as “IC recorder model name_current year_month_day”, e.g.
    ICD-BP100_2001_07_04. To add the messages as they are onto the IC
    recorder later on, save messages as DVF files.
    4 Click [Save].
    All the message folders and their component message files are saved
    in the specified file type by the specified folder name. The files inside
    the folders are automatically named according to the property setting.
  • 10,594 Answers
  • Shahid Electronics
    Shahid Electronics Nov 23, 2008
    Does your laptop recognize your Sony voice recorder and shows its files?
  • Sony Master
  • 19,396 Answers
You cannot install software for windows 98 on windows XP, if there is no driver the device cannot be used on XP.
  • Ginko
    Ginko Nov 22, 2008
    The voice recorder that you have is automatically detected on Windows XP.
    After connecting you should have a new removable disk popping up under "My computer"
    I understood you already installed digital voice editor, if you did not install it yet here is the download.
    Sony eSupport - ICD-P320 - Software Updates & Drivers
    You shouldn't need any additional software, if the recorder is not being detected automatically, then either the recorder or the system on the laptop has a problem.
No recognition
you might have to install the software in programs(86)
Nov 11, 2013 | Sony ICD-P320 Digital Voice Recorder
I NEED TO SAVE MY FILES OF SONY VOICE RECORDER ICD-PX 720 INTO MY MAC, BUT IT DOES NOT RECOGNIZE IT
Apparently, what you may already know, Sony does not make software supporting this device on anything other than Windows. So your best bet is to install windows via bootcamp, virtual machine or use wine as an emulator for windows programs. But since we're talking bout drivers the first solution is the one i'd recommend. I would happily help you install windows via bootcamp. You will need an original windows disk and you have to tell me what operating system version you are running.
Best regardsVlad
Jan 02, 2012 | Office Equipment & Supplies
Printer does nt work on laptop
  • Win 98 software version will never support Win XP system. Please download the software for your XP machine via the below link.
DOWNLOAD FULL FEATURE SOFTWARE
  • Save the download the file to your desktop.
  • Uninstall the older version, restart the computer and install the new version from downloaded file.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP DeskJet 840c InkJet Printer
Problems to make the sony icd-sx25 software editor recognize my hardware when i connect to pc with usb cable. using a windows vista home premium 64 bit operating system
There is Sony Digital Voice Editor Version 3.2.01 available to work on Windows Vista Home Premium 64-bit.
Click Sony Support to download "DVESetup_EN_3201" file (size approx 83MB) and install it in your computer, this will solve your problem of ICD-SX25
Thanks.
Jan 29, 2010 | Sony ICD-SX25 Handheld Digital Transcriber...
Usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Apr 02, 2009 | Crosley Traveler Turntable
Lost Original CD/drivers for Panasonic RR-US430
Software available here:
http://thepiratebay.org/torrent/4404636/Panasonic_Voice_Editing_2.0_Standard_for_RR-US430
Use BitTorrent to download.
Dec 15, 2008 | Panasonic RR-US050 Digital Voice Recorder
Sony ICD-B600 voice recorder
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
Jun 10, 2008 | Sony ICD-B200 Digital Voice Recorder
Getting My Mac to Recognize the Sony IC Recorder
you can only download it on windows and save as.wav and then copy it on the Mac. I couldn`t find any other way
Apr 08, 2008 | Sony ICD-R100VTP Handheld Digital Voice...
Vista upgrades???????
Go to My compter/Help/ and check out program compatability
The idea is to get Vista to revognise older software/systems
You shoulf be able to select XP/98 etc.,
Nov 05, 2007 | HP Officejet 5510 All-In-One Thermal...
Sony ICD-P320 Digital Voice Recorder Logo
107 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
