Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
If you turn the remote over there is a tab at the top push that towards the bottom of the remote and pull up. Once you have the battery cover off replace batteries with two AAA batteries. Click below for a copy of the manual. The battery replacement is on page 9 of 40 in the adobe document.
I need the remote mine got lost I hope someone has the code I will get a universal been trying to buy a replacement remote for my. Check on ebay or Amazon maybe find one listed ask the seller for help as I have help others that way, good luck. Ron
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
If using the comcast remote to control your dvd player, then review comcast manual for the codes for dvd. If the manufacture isn't listed or the codes don't work, then there might be a range of codes in the manual you can try. Otherwise you can contact your dvd manufacture on purchasing a new one or get a learning remote.
I had the same problem trying to use those three codes with a Samsung DVD-R155 recorder and then downloaded the pdf files for all of Comcast's remotes and came up with two codes (1) 20490 and (2) 21470. The second code worked for me. Hope that this will work for someone else.
