Question about Bernina Sewing Machines
How do I use the needle threader on my Bernina 1130?
I just do not know how to use it?
2 Suggested Answers
  • 11 Answers
SOURCE: needle threader is not working bernina 220 activa
Use a magnifying glass to see if the little hook in the needle threader is bent so that it is not going through the eye of the needle. You might be able to gently bend it back with tweezers.
Make sure that your needle is in the upper most position when you try and the presser foot is down.
Posted on Mar 17, 2010
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
When I bought my Bernina MO 203 over locker sewing machine and it didn't come with instructions. Does anyone know where I can find one, either online or in a store?
The following web site is very dependable so give it a try.
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
May 20, 2015 | Bernina Sewing Machines
Bernina artista 630 threading needle
Make sure your needle is in the correct position to get it to work.
Here is a nice little video on how to use these.
http://www.youtube.com/watch?v=vtWu-udWaB0
Aug 19, 2012 | Bernina Sewing Machines
Automatic needle threader on Bernina 135
check with
sewingmachinsplus.com
sewingstyle.com
thesewingoutlet.com
whitesewingcenter.com
May 31, 2012 | Bernina Sewing Machines
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
Needle threader is not working bernina 220 activa
Mar 02, 2010 | Sewing Machines
Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Nov 22, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
120 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
