Question about HP LaserJet 1020 Printer
Spooler srvice is not running
Hp 1020 is a network printer. The spool service is not running. How can I get to the spooler servise to make it run?
  • 1,218 Answers
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window.
On this window, scroll down and click
Posted on Sep 14, 2010
Posted on Nov 23, 2008
How to refill this gadget, how does it cost!
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
My hp deskjet ink adv2060 K110 not print the spooler service not running?
Hello there Marejen,
See if there is any spooler.exe running in your task manager. Press ctrl, alt + delete to go there. If you see the process, click to highlight then end it. Then restart your computer and the printer itself. Then try to initiate a print again once everything is loaded.
Please let me know if this helps. Thank you for using FixYa.
Aug 02, 2011 | HP Deskjet 2460 InkJet Printer
I can not print on my HP Laserjet 1020. It first asks that I install a printer before printing but when I try to install the printer it says that the local print spooler service is not running. It then...
try to restart the spooler system.
to do it:
1) click start
2) on the search box type Services and hit the enter key
3) on the windows that appear after you hit enter. Find priter spooler
4) once you find it. double click it.
5) on that window. and make sure that the startup type is automatic and finally click start.
Note: if the spooler service is already running stop it and restarted back in.
hope this helps
Jan 18, 2011 | HP LaserJet 1020 Printer
All of a sudden, I can't print on my HP LaserJet 1020 and I don't see it anymore on list of printers/devices. When tried to add printer, screen displays "Windows can't open Add Printers. The local...
Hi.
Here is the procedures
Go to START MENU
Choose RUN (For Windows XP) or Choose Commad prompt, right click and run as administrator ( Fow window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Jan 13, 2011 | HP LaserJet 1020 Printer
Hi, I?ve critical problem. I have a printer HP 1020 which is installed with my pc. And we have 10 PC in my local network. We use above printer share basis. But problem is when some one (without my pc) try...
The spool service basically holds what you want to print in memory and print it while you can do other stuff..
Check you spool settings here:
Although you can control whether to use spooling or not, you'll typically want to spool documents you send to printing. Spooling documents expedites the printing process, and allows the application that sent the document to release control back to the user much faster this link will show you the settings you can select but the real settings will take place inside your printer properties.
http://technet.microsoft.com/en-us/library/cc739118(WS.10).aspx
Hp 1020 spooler settings, unable to find the specific one but i believe when you go into the options just follow the steps provided in the link with similar images and try selecting a different spooler option, this can indeed affect what's happening with the printer versus the systems...
http://technet.microsoft.com/en-us/library/cc722526.aspx
Aug 12, 2010 | HP LaserJet 1020 Printer
WHAT WILL I GONNA DO WHEN MY PRINTER SPOOLER IS
click on start->run and type services.msc
and then look for print spooler service.just click on start service.if it is already started.then stop it and start it again and then restart your computer and it will be fine
Jul 27, 2010 | HP LaserJet 1020 Printer
PRINTER SPOOLER
Enable printer spooling in services option of My Computer Right click Manage option.
May 23, 2010 | HP LaserJet 1020 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
Spooler system is not running in 1020 laserjethp printer
start button
run
type services.msc
select print spooler
right click and select start
select properties and make sure it is set for automatic
Sep 11, 2009 | HP Hewlett Packard LaserJet 1022 Printer
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
153 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
