Question about Craftsman 4 Cycle Blower/Vac
I am gettinno spark from the spark plug I have put in a new plug,
Leaf blower won't start. I have replaced plug but am not receiving a spark from the new plug.
  • 163 Answers
First check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Posted on Nov 29, 2008
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Husqvarna blower #125BT won't fire over, has spark.
I have seen some issues with these machines shearing the flywheel key ( it is an alloy key part of the flywheel ) if the key has sheared it will knock the timing out and will now require a new flywheel.
Jul 07, 2012 | Garden
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
I have a homelite leaf blower model ut08544 that will not start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 19, 2008 | Homelite 'Yard Broom' Leaf Blower
Craftsman 4 Cycle Blower/Vac Logo
558 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
