Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony Wega KF50WE610
Took more and more starts to turn on and finally wouldn't turn on. A few days ago I replaced the lamp. Worked well a day or two. Now turns on, but turns off in about 3 minutes (no picture and no sound.) A few minutes later it turns on again and then turns off. When I fool with it I get bottom light blinking 5 times. Unplugged for 1 minute and plugged back in. Still same problem.
Any ideas?
  • pranav1974 Nov 26, 2008
    Bulb was already replaced several months ago but we do have the TV on for long periods of time.
  • 505 Answers
5 red blinks = lamp driver or ballast failure.
we610 part # = 1-468-798-14
replacement is straightforward when you unplug the set and open the back up. remove the metal support bracket to expose the ballast. make sure to keep all wires routed as you found them.
Posted on Dec 07, 2008
10 times to try to power on tv before it works
Check lamp door switch. If you short the wires together then you know its the switch. How long ago was lamp replaced?
Nov 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
50" Sony rear projection only 2 years old, will not curn on..
Your Fan could be bad, pull back off watch when you turn set on if fan stops running lamp and set will not come on. I had set that fan would sometimes run for all day then set would go back to not turning on. finally would not come on at all It was fan going bad.
Dec 20, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Nov 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Jun 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony Wega 60 LCD (model # KDF_60XS955)
below the lamp is a thermal fuse that has opened
Sony Part Number: 191002393
https://www.vancebaldwin.com has them in stock
thanks
scott
May 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
197 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
