Question about LG WD-3243RHD Front Load Washer / Dryer
Natural gas to propane conversion LG dryer
Should you be able to hear the burner during use after conversion...it sounds a little like a gas flame blowing in the wind and sounds like it is turning on and off during the drying cycle??
  • onetrakmnd Nov 23, 2008
    Didnt realize i posted under the all-in-one unit...this is just the standard LG dryer, I switched orifices..then turned the set screw down on the control valve...one other question, I have this attached to a standard BBQ small 20pound LP tank with the same regulator that goes on the grill....this should be ok shouldnt it??
  • 1,543 Answers
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Posted on Nov 22, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 23, 2008
    Yes, a 20 lb propane tank with a gas grill type regulator should work just fine. How about a FixYa rating instead of just the Helpful? Seems like you got a lot of good info, and I expect your dryer is working now, correct?
How do i adjust a gas burner on my blue stare gas range
It sounds like you have a natural gas burnwer, but are using propane as your fuel. If this is the case, order a propane conversion kit. Good luck!
Apr 15, 2017 | Heating & Cooling
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
LG Gas Dryer to use Propane vs natural gas
The difference between a natural gas appliance and a propane one is basically the gas nozzles. For example if you have a gas stove and you lift up the top, under the burners are the small gas nozzles. The problem is there are no standard when it comes to these nozzles. In other words they are not interchangeable form one brand (Whirlpool to LG) to another or from one type (washer to furnace) to another. What you can do is contact you locale propane dealer and ask them if they have any suggestions. Also look on line for sites that may offer conversion kits like RV dealerships.
Hope this helps.
Sep 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Whirlpool gas dryer. I have gone from a natural gas hook-up to propane. Is there anything I need to do different for that natural gas installation?
You will need to change the gas discharge jets on the burner so that the burner gets the proper mixture of gas and air. Propane accessory stores should be able to furnish a conversion kit.
Aug 21, 2009 | Dryers
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
LG WD-3243RHD Front Load Washer / Dryer Logo
869 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
