Question about Canon PowerShot S1 IS Digital Camera
Display blurred and cam showing low batt
I have Canon Powershot S1 1S. It was working fine until yesterday when i put in fully charged batteries. The LCD dispay screen is all blurred and the cam showed lo batt within 5 min. I have even tried with fresh battries however the same problem continues. I am however able to view thee previous snaps clicked on the cam properly. So the problem is only in cliking fresh snaps. Coral
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
Re: display blurred and cam showing low batt
Bad luck is that the CCD sensor in your camera has stopped working properly and needs replacing. You are lucky though because Canon repairs this fault on S1 - IS free of charge so phone them and inquire.
Posted on Sep 27, 2007
0 characters
3 Points
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
Battery problem?
i have this excact same camera ... happened to me... it will work after a little bit, open battery door and let sit for 3 days, other wise turn screen off
Oct 21, 2009 | Canon PowerShot A430 Digital Camera
Short battery using NiMH batteries
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Sep 28, 2008 | Canon PowerShot A85 Digital Camera
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Aug 29, 2008 | Canon PowerShot SD870 IS Digital Camera
Blurred pink LCD picture
This is a manufacturing defect. Send the camera to canon repairing shop.The will do it free of cost.
I had the same problem,
Jul 14, 2008 | Canon PowerShot A95 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
May 27, 2008 | Canon PowerShot A540 Digital Camera
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera won't power on
All digital cameras contain power units called DC/DC converters. Power failures can be caused by failed converters and/or blown fuses.
Apr 27, 2008 | Canon PowerShot SD600 Digital Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot S1 IS Digital Camera Logo
77 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
