Question about Kodak EasyShare C743 Digital Camera
Memory card needs formatting
When I try to hit continue, it won't do anything it just keeps saying formatting will delete everything on the card ... and then when I hit continue it goes back to the memory card needs formatting screen
  • memoryhelp Nov 22, 2008
    ditto... I have the exact same problem. I hit okay to format... it says Memory Card is formating. But, it doesn't format. It then says "Format" or "Cancel"...
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Kodak EasyShare CX7525. I cannot get my new 512mg SD card to format. Have followed instructions to format, but after I hit continue when it says formatting will delete everything on memory card, it then...
c2e78578-9d52-4a0d-a193-0441b13c4050.jpgpull the card out. there's a small piece of plastic on the left edge that should slide up and down. one position is read only, the other is read or write.
Nov 05, 2013 | Kodak EasyShare CX7525 Digital Camera
8GB SD card says: MEMORY CARD REQUIRES FORMATTING After selecting continue SD card says: FORMATTING WILL DELETE EVERYTHING ON MEMORY CARD after selecting continue it says: FORMATTING... but then returns...
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Jan 06, 2011 | PNY 2GB microSD Memory Card
Memory card requires formatting, press continue then it states that it will delete everything on memory card,then it does not format, it tells you that you need to format memory card. press cancel and...
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
Dec 09, 2010 | Kodak EasyShare Z7590 Digital Camera
Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
Camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Jun 04, 2009 | Kodak EasyShare Z7590 Digital Camera
New memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
Camera/computer say memory card "needs to be formatted".....
i would save your pictures on to a disc, then re-format the card.
Jan 25, 2009 | Digital Blue EasyShare MD1063 Digital...
Hi Mr.
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 30, 2008 | Kodak EasyShare DX4530 Digital Camera
    Memory card
    this cam will work up to 2gb sd/mmc
    what's the capacity of your card? if it's above that, it's really not gonna work with this cam
    if your card is 2gb or lower
    2 possibilities:
    defective card - please try another card
    camera memory reading problem - arrange repairs with kodak
    Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
    Kodak EasyShare C743 Digital Camera Logo
    175 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
