Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Kitchenaid kcms185jss2 close the door and it starts.
  • Mickey Willey
    Mickey Willey Nov 22, 2008
    tried the breaker to reset and it didn't work. How do I remove the keypad if this is the problem?
  • KitchenAid Master
  • 9,098 Answers
First we should determine if it's actually cooking when you just close the door, or if it's only the light and fan running.
You can test it by putting in a cup of water and closing the door for 30-60 seconds, then checking to see if the water is warmer.
If it is actually cooking, then it's your control panel that needs to be repaired.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
If it is not cooking, then you have a problem with the lower door switch (primary interlock switch) or its mount.
That's a pretty easy DIY fix. At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can see this file:
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Posted on Nov 24, 2008
Kems307dbl6 KitchenAid microwave staying on after you turn it off.
If the magnetron is still operating when off, needless to say , its pretty dangerous. The door lock unit usually has at least 3 microswitches to ensure that the door is closed and ready to operate. 1 of the switches is a safety switch which will cause a dead short if the door is forced open or something goes wrong with the door not closing correctly. This will "blow" the internal fuse in the machine. If the magnetron keeps going, its possible one of these switches have failed or there is an electronic fault causing power to the magnetron in the off position although, I would strongly feel this would be unlikely. These machines are made with a lot of safety devices.
Jan 28, 2018 | KitchenAid Microwave Ovens
How do I fix the problem?
really a good probability it is defective .
Jun 25, 2015 | KitchenAid Microwave Ovens
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
Jan 27, 2015 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
When i try to turn on the microwawe it flashes "door" and will not start. It appears to be sealing normaly
It sounds like the door sensing (primary interlock ) switch is bad. Sometimes, the contacts can get dirty and not close to zero ohms, telling the CPU that the door is closed. It could also be a loose or dirty connector at the switch or a loose ground. Then, possibly a bad control PCB.
Sep 14, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KCMS185JSS2
Since the noise is louder, I would suspect a shorted high voltage rectifier diode or failed magnetron.
That model may have a 5-year warranty on the magnetron.
Your owner's manual and warranty guide can be downloaded here, and on that same page you'll find Customer Service contact info.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
107 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
