My Behringer BXL3000A bass amp's volume control makes a noise, so what could be the problem?
  • 71 Answers
If the noise appears only when you rotate the control, there is dust inside it. With the amp disconnected from mains, rotate the volume control from min to max back and forth for about 30 times. See if this helps. This is not a definite solution, you maybe have to replace the potentiometer or spray some potentiometer cleaner. Good luck!
Posted on Nov 23, 2008
Behringer Eurolive B215B. Why does the bass cut in and out?
This could be caused by bad soldering on the controls. A quick touch with a soldering iron to the control terminals might solve the problem.
May 26, 2015 | Behringer Audio Players & Recorders
Behringer djx700 has no bass
Check that all the eqs are set not to cut bass, check there are no effects on and that the XPQ is off. If you still have the problem how sure are you there is no bass coming from the mixer? Have you tried it with another amp? We had one hire customer who had the same problem you describe and his amp had a crossover and it was set to act as a mid/top amp and wasn't giving him any bass, unsurprisingly, switching it back to full range sorted it.
Dec 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi folks...I have a Behringer HA 400 Micro Amp. My question is: as I am a bass player/guitarist. Can I put my bass or guitar through this device. I understand that it will accommodate 1 instrument at a...
You can put just about any instrument through any amp. The difference in sound will be whether or not that amp was designed for the particular frequencies of that instrument. Also whether or not the speakers you are using are designed for those frequencies. When playing bass you need speakers designed to carry low frequencies (40 - 400 hz); mid-ranges and tweeters don't cut it. Set your instrument volume on the guitar at 70 - 90 % to get the most signal from the instrument. Set output volume on the amp at 50 - 70 %, then adjust gain on the amp to get required sound level. You're not likely to blow the amp, but you could blow the speakers if the amp delivers more power than the speakers can handle. With a micro amp check the output rating. It's possible you may not have enough power to get the sound you want and as you turn up the gain the sound will distort.
Nov 04, 2017 | Music
As soon as I turn the volume over approximately 40W, the speaker keeps moving while making an awful sound at the same rhythm. I believe the speak may be burned. Is there a way I can fix it or I have to...
How do you know you are at 40 WATTS? This takes electronic test equipment to measure.
Tests to run. Observe the speaker cone with power off. Now turn it on... did it displace and stay there? If so you have a failure of the amplifier itself. Next, If you can place finger on the cone, move it gently in and out feeling for any roughness. If you feel roughness, the voice coil is fried and you be buying new speaker. A lot of the Ultra bass Behringer's use LM3886 power amp chips... sometimes in parallel, and a failure of one could cause this.
Aug 23, 2011 | Behringer Ultrabass Bxl3000
Clip light is on even when no input and when bass is plugged in input low volume and distortion at speaker output
One half of the power amp has failed. You can damage the speaker... do NOT use this until repaired.
Apr 14, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
Hey, just purchased some behringer ms 40 near field monitors and after a few hours of playing at around the 1/4 volume mark i decided to turn the bass up. As i did so the right monitor began to make a...
The setting of the volume controls bears LITTLE importance to the actual level the unit is being run at since one can send high levels INTO the units from the source. These are intended to be used in a studio for the audio engineer to listen to in a small room. They should really be no louder than a consumer BoomBox maximum.
A squeaking noise is not normal at a level such as mentioned however. You might see if the noise is from the speaker itself or possibly parts of the cabinet... Plastic parts are NOTED for squeeking and can be suitably lubricated.
Beyond that, since the units are new, you should be able to exercise your warranty.
Mar 10, 2011 | Behringer Ms40 40w Active Powered Studio...
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 | Music
Behringer Bass V-Amp
In my xvamp, a strucked microbutton caused E2. I've replaced the button, and everything went right :D
Nov 29, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
75 people viewed this question
 Grubhead
Grubhead
