Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Monitor not Running(shows only orange light)
Hi Friends, Actually I opened my PC after some months. When I plugged in all connections, monitor didnt start up. It was showing orange light. I checked CPU fan was running,KB running,CD-ROM running but monitor didnt. Could anyone suggest what might be the problem? Thanks & Regards, Gaurav
  • Anonymous Mar 15, 2014
    IN THE BIOS BOTH MY CPU FAN AND POWER FAN ARE SHOWING ZERO REVOLUTIONS BUT A VISUAL CHECK SHOWS THEM TO BOTH BE RUNNING AS NORMAL. ALSO I WOULD ASK WHAT THE FOUR PIN CONNECTOR DIRECTLY BEHIND THE POWER CONNECTION IS FOR.THANK YOU.
  • 3 Answers
CHECK MOTHERBOARD OR VGA CARD OR RAM..REFIX IT IF NO USE, ONE HARDWARE IS FAULTY FROM AIRDACOIT.
Posted on Oct 22, 2007
  • 385 Answers
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Posted on Mar 21, 2007
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 14, 2014 | Soyo Computers & Internet
Why screen not coming on
Jul 06, 2014 | Compaq Presario S6700NX (DQ182A#ABA) PC...
Hello, I use pc computer and my monitor is of dell IN1920B but I have a problem that its display goes off while working but power light is on and media player and other program still gets running.
Good luck.
Jul 05, 2014 | Computers & Internet
Why is just the fan only running
Try another monitor.
Jul 02, 2014 | Gateway GT5670 Desktop PC
Everything is not working, the monitor light is still orange
If your monitor goes off and your PC is running and monitor display has appeared. The sign of orange light shows that there is a fault in monitor. The solution is that provide the heat or sunshine to monitor for 2 hours and then your monitor work well guaranteed.
Good Luck
Feb 24, 2011 | Dell Dimension 2400 PC Desktop
Turn on & no video
Step1: The light on the monitor is blue when it is on? And orange when in sleep mode? Check to make sure all the cables are plugged in completely. Perhaps the video cable attached to the CPU is loose. Step2: First of all, check all the cables and make sure they're all securely connected. if you can, hook up your computer to a different monitor and see if it was the monitor. If that didnt work, you may wanna open up your computer and check to see if the video card is in place and fully in. And if that doesnt work, if you really wanna go the extra mile, borrow a friends video card, install it, and try to boot up your computer. Best Of Luck
Dec 06, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Mar 03, 2009 | ViewSonic VA702B 17" LCD
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
505 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
