Question about Microsoft Xbox 360 Console
Xbox 360 xclamp fix done now it boots but no power
I fixed my xbox 360 with the xclamp fix now i want it to overheat but its boots up but no power runs though it to heat up... whats wrong?
  • knighthorse8 Nov 23, 2008
    yeah the lights blink but the system is off for some reason is turn the fan on for a sec than its off with the lights blinking still something wrong...
  • nvergara84 Feb 05, 2009
    I'm having the same problem fixing another xbox, i had the same problem with the first one i fixed but all i did was took the washers off the heatsink for the gpu chip and put the washers on the screwhead part of the screws for the cpu chip. its not working for this one though...
I had the same exact problem and after some troubleshooting I noticed scratches on the back of my motherboard. My guess is the broken traces/damaged motherboard from taking off the x-clamps is causing this problem due to the motherboard shorting.
You could possibly fix this problem with a conductive ink pen and some other trace repair items if you see the broken trace. Other than that for the average 360 repair man I think your outa luck just like me : /.
Next time be more careful!
Posted on Feb 22, 2010
  • 63 Answers
So, you Red Ring fixed your 360 and now your trying to overheat it and there's no power to the Xbox? I want to make sure I understand your problem correctly.
Posted on Nov 23, 2008
  • Collin Haugen Nov 23, 2008
    Give a little bit and I'll try and find out what's wrong.
Make sure you have the video cord plugged into the 360. if you don't, I've read that the computer won't turn on without the video cable in, and it will flash all 4 red lights. Good luck!
Posted on Jan 02, 2009
My xbox wont read xbox games but plays dvd`s,ive replaced disc drive and done the xclamp procedure.any ideas how i can fix this??
Since you've already replaced the drive and done the other procedure, you're best bet is to get in touch with xbox directly as it may be a software issue now. 1-800-4MY-XBOX
Aug 31, 2010 | Microsoft Xbox 360 Console
Ring of death on my xbox 360 any ideas how i can fix this
yes you need to open your xbox and (unfasten xclamp on underside of motherboard) remove the GPU and CPU units...remove all thermal paste and apply new thermal paste...reasemble GPU and CPU units attach all cables and dvd drive and boot system up...if you have done everything right then your xbox should be as good as new....but if you still have warranty on your system just send it back to microsoft
Apr 27, 2010 | Microsoft Xbox 360 Console
After xclamp fix 480p works but not 720p!
It is most likely GPU related. I have heard many stories of GPUs just not being able to handle HDMI. You can try the x-clamp fix again, until it works. But that's your only option.
Mar 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 console will not show video or audio on hdmi or regular video cables on any tv. console is on and running. before it stopped the picture was distorted.now will noy show anything.how to fix?
xclamp fix,the thermal paste on your heatsinks needs replacing,just done one the same last week,it had no picture but had sound and no light on red ring but sound went off shortly after.You can learn how to do this on youtube,just search xclamp fix and plenty will show,and buy a xclamp kit off ebay,will cost about £2,if console is still under warranty for the first year its covered but if its past the first year the extended 3 year warranty dosnt cover this repair.They will charge £81 for them to fix it.And dont do towel trick it will get it working again but only for a few days and will do more damage to console
Feb 11, 2010 | Microsoft Xbox 360 Console
Hi... i have three lights flashing? can you help please
itz rrod......
or may b due to power failure,
chck unplugging all plugs frm ur 360 n reconnecting it, if it works then its nt a rrod, if it doesnt ...
then itz rrod, u need to send your xbox 360 to fix it..
or need to get it xclamped:
here is the whole process to do a permanent fix *xlcamP* of rrod on ur xbox 360:
http://www.megaupload.com/?d=2LEW79G4
Dec 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 red ring of death fix
hi follow this link for an easy step by step guide on how to fix rrod its actually pretty easy
http://www.youtube.com/watch?v=Sv1kbNePvus&feature=fvst
hope this helps
Sep 08, 2009 | Microsoft Xbox 360 Console
Xbox360 has 3 red lights
Its when the solder overheats and disconnects a wire in the xbox. If you have bought it within the last year, you can return or swap for new wherever you bought it. If not you will most likely have to send it off to xbox repairs.
Apr 01, 2009 | Microsoft Xbox 360 Console
RED Ring of death xclamp fixed but..
Do you have the fan in? If you do, take it out or put 2 screwdrivers through the back holes to stop the fans from spinning. IF you have the fans out and its still not overheating, just leave it on for a while until it does. It will overheat eventually.
Nov 22, 2008 | Microsoft Xbox 360 Console
My 360 turns on for a mili second then no power fan stops
from what ive been told during my searches to fix my 360 it sounds like a blown mosfet. go here: http://forums.xbox-scene.com/
Nov 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture
Here is my recommendation
If the xbox is still under warranty (I mean no one has broken the sticker) don't open it yet
The reason for this is microsoft will warranty an xbox 360 against the three RROD
The problem you are having is/maybe related to the same thing and what is happening is the graphics processor is no longer responding properly.
Many others on this site have recommended a fix that I am hesistant to recommend, but does work, TEMPORARILY.
I only recommend this fix if you are trying to preserve the console s warranty as this is a non invasive fix.
All you need to do is wrap the console up ina thick blanket or several towels (do not use wet towels as water damage is not covered under warranty) and turn the console on.
This will cause it to super heat and eventually overheat
(this is not particularly good for the console, or permanent)
Once it has overheated (about 45 minutes in the towels/blanket)
unwrap it and let it cool.
After about 1 hour of cooling try to restart the console and see if you have video
For an out of warranty more permanent fix try the xclamp replacement mods outlined in other sections of this forum or search on google for xclamp replacement
May 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
786 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
