Question about Asrock 775Dual-880 Pro Motherboard
775Dual-880 Pro cannot detect SATA HDD 320gb - Asrock 775Dual-880 Pro Motherboard
  • 1 more comment
  • joao_paraivo Nov 23, 2008
    The motherboard bios...Thanks
    I think the problem is in the speed drive. I motheboard just receive SATA 1.5 Gb and the disk its 3 Gb. In the samsung site, they speak in a patch to switch the speed. I try make the patch but its not working.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    the motherboard bios or the windows install?
  • Asrock Master
  • 4,806 Answers
If you bought this board brand new, take it back and tell them the sata controllers in the bois are not sufficent and get one that is. If you got it second hand then you will need to update or flash the bios to the latest version. see if that works and the drive is recognised. if it is recognised via flash/update you may still run into problems if you try to install XP
good luck and regards
Posted on Nov 23, 2008
  • Lee Hodgson
    Lee Hodgson Nov 23, 2008
    shouldn't make any difference, the board is supposed to support sata 2 and doesn't, try to clear the cmos with the drive plugged in, that should set it back to defaults, also have a look in the bios settings, in some boards you have to enable the sata controllers yourself, if this does not work then its a bios flash or you will have to get a ATA/IDE drive instead if the board supports it
    good luck
Can my WD 5002AALX SATA3 work with 775dual-880Pro motherboard?
Hi, yes you can but you have to format the drive before you can use it.
You can download a manual from here:
You can format the drive in the disceditor.
Aug 30, 2011 | Asrock 775Dual-880 Pro Motherboard
My motherboard does not pick up my sata hard drive at all. can you help?
in first turn of pc, remove power cable from hdd and put agin, then from bios find load default setting, enter on it then F10-sav and exit.
Jun 14, 2011 | Asrock 775Dual-880 Pro Motherboard
Cabel connect problem on the bord power sw reset sw hdd led connecting pins ???? i don't have a plan of the bord
Please refer to the Product user manual. You can download it from the following link: -
Hope this helps!!
Nov 14, 2010 | Asrock 775Dual-880 Pro Motherboard
775Dual-880 Pro cannot boot sata
Have you tested the same with IDE ODD ? Check SATA drive is detected in BIOS. If yes enable IDE simulation in BIOS
Oct 02, 2010 | Asrock 775Dual-880 Pro Motherboard
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
Hard drive
Some motherboards support both IDE and SATA so it is not unlikely for your MOBO to have both. There should be some mention of SATA in the motherboard BIOS screens so have a look see. Otherwise just plug in a SATA device to it and see if it works!!
Sep 26, 2009 | Asrock 775Dual-880 Pro Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Oct 17, 2008 | Asrock 775Dual-880 Pro Motherboard
PC Help
Find the SATA Driver for the Hard Drive. It has to be installed first.
Apr 02, 2008 | Asrock 775Dual-880 Pro Motherboard
Unplug both ram dim. Plugin one single ram dim and check. Remove first and plugin second dim then check is detected ? If both are detected one by one then check clock speed of both rams , it should match, otherwise only one will be detected. Also check motherboard manual for supported ram eg. ddr1, ddr2 , cloack speed etc.
Oct 13, 2007 | Asrock 775Dual-880 Pro Motherboard
Asrock 775Dual-880 Pro Motherboard Logo
1,306 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
