Question about HP Deskjet D4160 InkJet Photo Printer
Ip address of hp deskjet d4160 to add printer in network
I need ip address and Port name of hp deskjet d4160 to add printer in network. Any help will be appreciated.
Sayeed
  • 495 Answers
For getting the IP address, first you have to check printer settings from printer LCD display panel. Or alternatively you can search for network connected printers and then install it.
Posted on Dec 02, 2008
Set up wirelessprinter hp
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Jan 28, 2013 | Office Equipment & Supplies
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
on Dec 06, 2009 | Computers & Internet
I have 2 6100 series HP printers in two different locations. One wireless and other Ethernet connection. I get no problem. Now I installed at a third location an HP 6500 E709n series unit and have all...
That might be because of the clash in the Print drivers.
Installing the Universal print Drivers is suggested.
You can use both the printer with wireless connectivty using such drivers.
First install the printer with Full feature driver.
Then go for Universal drivers.
Make sure that you have the correct IP address and both printers are not clashing in this regard.
Install these inbuilt drivers with separately with different IP address.
To add a new printer, connect your computer to the network and click Start > Printers and Faxes.
Click Add a printer in the Printer Tasks column of the Printers and Faxes window
The Add Printer Wizard will open. Click Next.
Select Local printer attached to this computer, and be sure the box under this selection is not checked.
Select Create a new port and select Standard TCP/IP Port from the Type of port drop-down. Click Next.
The Add Standard TCP/IP Printer Port Wizard will open. Click Next
Enter the IP address of the printer in the IP Address or Print name.
A confirmation screen will appear indicating that the wizard was able to locate the printer. Click Finish
Under Manufacturer , click HP , under Printers , click hp deskjet 990c , and then click Next .
Use default printer name. Set it as default.
Click Finish to complete the setup.
Mar 08, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
Sep 02, 2009 | HP LaserJet 4050tn Printer
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Network printer support how do I connect 2251N printer to wired network I have samsung printer 2251N and wireless network. Can I plug printer into modem and use wireless laptop to print documents?
http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
http://www.stanford.edu/services/ess/pc/docs/xp_printer/index.html#anchorone
http://www.online-tech-tips.com/windows-xp/how-to-install-a-network-printer-on-your-home-or-office-network/
Setting Up a Network Printer
Preparation
In order to install a network printer, you must know your printer's Manufacturer, Model Name, and IP Address.
The Manufacturer and Model Name can be found on the printer case, an example is HP LaserJet 4000N. The IP Address can be found on a label attached to the printer. An example of the IP Address is 141.161.888.999. If your printer does not have a label indicating the IP Address, or you can't identify what model it is, please call your printer manufacturer.
1. Click on the Start button, then click Control Panel, then click Printers and Faxes, then click Add Printer.
2. A new Add Printer Wizard window opens. Click Next to start.
3. Select Local printer attached to this computer. Make sure Automatically detect and install my Plug and Play printer is NOT checked.
4. Then click Next to continue.
5. We will create a new port for your network printer. Select Create a new port.
6. Beside Type of Port, click on the down arrow, then click on Standard TCP/IP Port.
7. Click Next to continue.
8. A new Add Printer Port Wizard will open. Click Next to continue.
9. You must now type your printer's IP Address in the Printer Name or IP Address field.
10. The Port Name will automatically be filled when you enter the IP Address. Do not change the Port Name.
11. Click Next to continue.
12. IF YOU HAVE PROBLEMS, then you will see the screen on the right. This means that the IP Address for the printer is NOT available on the network. Select the Back button and make sure you entered the correct IP Address. Check to see that your network printer is powered on and displays a 'ready' status.
13. IF YOU DID NOT HAVE PROBLEMS, Windows XP will scan the network to find your printer's IP Address. This may take a few seconds. Select Finish to continue.
14. You must now select the printer's manufacturer and model. Windows XP will automatically select the detected manufacturer and printer driver. Normally, you will not have to change this selection.
15. OPTIONAL: If your printer is listed but you have more than one printer model to choose from, please select the model with PS, if available.
16. IF your network printer is NOT automatically detected, select the Windows Update button to find the proper software drivers.
Note: If your printer is not automatically recognized using Windows Update, please call your Help Desk.
17. You will be prompted to confirm the selected printer driver. Make sure Keep existing driver is selected, then click Next to continue.
18. You will be prompted to assign the printer a Name. You can use the default name, or add more info to indicate the printer location, such as My Office, Hallway, Foyer, Room 222, etc.
19. Select Yes if you want to use the printer as the default printer. Click Next to continue.
20. You will be prompted to share the network printer. Do NOT share the network printer.
21. Click Next to continue.
22. You will be prompted to print a test page. Select Yes, then click Next.
23. Check your network printer to make sure your page printed. Select Yes when prompted to confirm a successful test page.
24. Click on the Finish button to complete the Add Printer Wizard.
Congratulations! If your test page printed, you have successfully installed the network printer.
Note: If you had problems and did not get a test page, please call your printer manufacturer.
Mar 30, 2009 | Samsung ML-2510 Laser Printer
HP Deskjet D4160 InkJet Photo Printer Logo
336 people viewed this question
Seeker5211
Seeker5211
