Question about HP 530 Notebook PC
Hp 530 Boot Proplem
Hello Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I have a hp530 notebook, I've just bought it andwhen i turned it on earlier it get to the part where you Wont see
any thing the screen goes black and that's it.
  • mallisuni Dec 04, 2008
    yes i have same problem.some times we put cd or dvd its not working properly.
Tip
Sign of Virus Infection
You can easily identify when yourcomputer system gets infected from viruses. Some of the signs of virusinfections are enlisted herewith: Computerbecomes very slow in performance.
Suddensystem crashes and computer reboots repeatedly.
Applicationsoftware crashes and random messages are displayed on the monitor.
If you find any of the above mentionedsign on your computer system, then there arises the probability of yourcomputer being infected with viruses. The next step after detecting thepresence of virus on your PC is to remove them from your system in order tosave your important data. If your computer is not infected with any type ofmalicious software then it is strongly recommended to install any bestantivirus software to keep it safe against the attacks.
on Jan 28, 2010 | Computers & Internet
Tip
Buy a TV is like when you buy a car!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When you buy a TV is like when you buy a car. You are looking for the best @ the best price. And its exactly de same you need to give itmaintenance and clean it not every week bout yes like at lease 3 months Isuggest you make some research beforeyou buy a nice DLP you need to see how much will a lamp cost and what are the problems if you buy a DLP you will defiantly need atsome point a replacement lamp. Bout remember clean you TV and any strange noise go on warranty or make some research I can gladly help on some things for theDLP’S Happy hunting for a new TV a197830.jpg ba5e86e.jpg3150202.jpg including kid's now how t buy a television..
on Jan 27, 2010 | Televison & Video
How to replace Sony Wega KFWE42S1 lamp
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How much will it be to replace my lamp?
It all depends on the type of lamp and manufacturer u has, some brands are compatible that is always a good thing.
Example:
LG, Zenith, Mitsubishi, RCA, Samsung, and some Panasonic they use. Philips so you can save money we just need to know if the model is compatible.
The cost is around $85.00 the cheap ones $114.00 Philips and like $299.00 again depends on the brand and ho is the one that sales!
There are a lot of good online stores that can send you a lamp usually for a lower price here are a few links that I can found if you need them.
http://www.discounttvlamps.com/
http://www.purelandsupply.com/
http://www.discount-merchant.com/
http://lamps4less.net/
good luck..
Apr 20, 2010 | Sony Grand WEGA KFWE42S1 TV
I have a Fridgidaire stove FE369COSE. Ran self cleaning cycle but now oven door won't unlock. Oven is cool but an error code of f9 is flashing. Does anyone have a solution? jadimin
I've had this happen with my Frigidaire stove too. The "locked" light is on.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Open the oven door and locate the light switch. Hold it in - sometimes it makes a noise and resets it.
If that doesn't work, push the Clean button and the Cancel button simultaneously and hold for about 30 seconds. The “locked” light should disappear. If it is working, you’ll hear a mechanical hum as it resets.
Apr 14, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Tip
Secret Codes For SGH-600/SGH-2100
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the secret Codes for SGH-600 / SGH 2100
  • *#06# -> Show IMEI
  • *#9999# -> Show Software Version
  • *#0837# -> Show Software Version (instructions)
  • *#0001# -> Show Serial Parameters
  • *#9125# -> Activates the smiley when charging.
  • *#9998*228# -> Battery status (capacity, voltage, temperature)
  • *#9998*246# -> Program status
  • *#9998*289# -> Change Alarm Buzzer Frequency
  • *#9998*324# -> Debug screens
  • *#9998*364# -> Watchdog
  • *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
  • *#9998*427# -> Trace Watchdog
  • *#9998*523# -> Change LCD contrast - Only with version G60RL01W
  • *#9998*544# -> Jig detect
  • *#9998*636# -> Memory status
  • *#9998*746# -> SIM File Size
  • *#9998*778# -> SIM Service Table
  • *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
  • *#9998*837# -> Software Version
  • *#9998*842# -> Test ******** - Flash the screenligth during 10 seconds and vibration activated.
  • *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
  • *#9998*872# -> Diag
  • *#9998*947# -> Reset On Fatal Error
  • *#9998*999# -> Last/Chk
  • *#9998*9266# -> Yann debug screen (=Debug Screens?)
  • *#9998*9999# -> Software version
Enjoy. :)
on Dec 14, 2009 | Cell Phones
My wife not getting pregnant!!
my wife is prehnant but we don't want child and don't tell any one of my family so how to miscarrage
Mar 16, 2009 | Adler Royal Office Equipment & Supplies
Tv wont turn on
You have shorted transistors on deflection board just fixed one like that will have to get back to you as to where the parts are located on deflection board.
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
Placing date/time on the photo
Oddly enough Canon thought that people would only want date stamps on "Postcards". The date stamp options is only allowed when you select the "Postcard" size (1600X1200) in the function menu.
I hope this helps!
Nov 22, 2008 | Canon PowerShot A85 Digital Camera
HP 530 Notebook PC Logo
626 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
