Question about RCA P52926 52" Rear Projection Television
I need to re-align the guns. I don't remember how.
The fuse by the power cord blew out and while I replaced it I vacuumed out the cobb webs from inside. When I put it back together, at least it came on, which it failed to do before. But the guns are out of alignment. I remember aligning them when it was brand new. I cannot find my manual. There does not seem to be an option that comes up for me to do so, now. Even though your site says there is no such thing, and I picked the closest I could find, my registration card for this product claims it is Model Number P52928YX2. It is a 52 inch Rear Projection Television. Something like 1999 model.
    Problem Solver:
  • 31 Answers
I belive you have a problem on the convergence circuit, a problem on the power supply of the convergence it blow out the fuse, if you cant find the option on the menu how to adjust the convergence that confirm it
Posted on Dec 02, 2008
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
I have a 1989 cobra 29 Ltd classic cb. It got water spilt on it sitting on my tabble so I took the covers off and took a heat gun to it and dried it. I also disconnected the internal speaker and left it...
# 1 you should never dry out a radio with a heat gun.#2 the reverse polarity diode is what is blowing out. take that wire you fixed and toss it.go to Rad Shak or a truck stop and buy a power cord with a lighter plug attached. .Then have someone you can trust replace d23. hook up your coax then your cord turn it on and you are good to go.
Aug 01, 2013 | Radio Communications
Chevy Avalache 2007 blew a fuse while getting a jump, car won't start, rear windows and power locks don't work
You blew more than 1 .
The HUGE MAXI FUSE is probably burned... IF I remember correctly, it is a 80 or 100 Amp
Apr 06, 2013 | 2007 Chevrolet Avalanche LTZ
Acoustic Solutions Tv model ASTV3619ws, has begun to blow fuse in plug!!
Hi bledger517,
Make sure that you've replaced the fuse with exact ratings. Low ampere ratings will not handle current as what the original fuse installed. If still fuse keeps blowing after replacing with the same rating, this is an indication that you have a short on the power supply section. It can't be fixed by replacing the fuse alone. Short usually near the AC line where parts like the following are present.
  1. Power Cord - even very low of chances but still to be check
  2. Rectifier diode
  3. Main filter electrolytic capacitor
  4. Voltage regulator I.C.
This is the common parts that might be shorted and made the fuse blew. You may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 25, 2011 | Televison & Video
When turned on caused, caused a pop at the outlet and don't know if the if the power cord went bad or short somewhere else in the sustem. what do i do and how
Hi, that pop sound you heard at the outlet simply implies that the fuse blew off. What you just need to do is too replace the fuse and if the power cord is having a burn smell, then i will also advise you to change the power cord..
Take care
Apr 03, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Cord replacement
try this web site .you will need your model .number http://www.toolpartsdirect.com/dewalt/dewalt-18.html
Mar 11, 2009 | Dewalt 6.3 Amp Dry Wall Screwdriver
My cash registerSharp XEA202 does not turn on
Hi and welcome to FixYa,
As far as remember, there are 2 - 4 screws at the back of the cash registrar.
Remove the power cord from the wall outlet.
Remove the screws.
Lift the top gently from the back up.
Pull the plug to the top display (remember where its situated :-)).
at the back, near the power cord is a power supply, in there is a glass fuse (there might be 2, but you can see which one is blown), - that’s the one you need to replace....
Regards
/Teis -> don’t forget to vote, ex. “FixYa”, thank you.
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
Cobb cooker instructions
go to there web site and download the instructions and cook book in a pdf file
Aug 11, 2008 | Cobb Grilling
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
RCA P52926 52" Rear Projection Television Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
