Question about Yamaha HTR-5930 Receiver
HTR-5930 Speaker A/B setup
I have a Yamaha HTR-5930. I have the ability to hook up speaker A to play in one room and Speaker B to play in another. I had an older receiver hooked up and it worked fine. I can't figure out if I have a setting wrong. I have them plugged into the front speaker left and right but only get sound out of one. It only works in one room, speaker a controls left speaker, speaker b controls right speaker instead of both working but in different rooms.
  • 5 more comments
  • asgamer Nov 22, 2008
    I only want speaker a or b to work one at a time. It is only working in one room, not the other. When switched to speaker b nothing comes out in the other room. It ust switches which speaker it comes out in the main room.
    I believe they are single channel. They are speaker wires that I put into the back.
    I have it hooked just on the front speakers. The main room only has 2 speakers and the 2nd room has 2 speakers for left and right. But I can't get it setup to recognize the other room. It seems like there is a setting that is setup correctly.
    I have pushed the speaker button and the display shows me which one is one. Speaker A is suppose control the main room, while speaker B controls the 2nd room. But Speaker A is controlling the left speaker and Speaker B is controlling the right speaker. So it is not controlling it by room only speakers. Again, I had an old receiver with A/B speaker setup and it worked fine. Now the new one I can't get working properly.
    I know that I don't need a splitter my other receiver didn't and was much older. This was hooked up in another home with the exact same setup. Each room only has 2 wires left and right speaker. So I have both rooms with the left and right speaker wires hooked up. Somehow the sound isn't coming out. These speakers were pre wired when it was constructed.
    I understand why you think that but I unhooked the old one and hooked the new one up within minutes. And the fact that when speaker a is on, it should come out of both left and right speakers in that room but doesn't, only comes out of one. When Speaker b in on, nothing comes out of the 2nd room speakers but in the main room where only 1 speaker was working, when b is selected the other speaker works. So it is only working in 1 room, not the other and flipping between a and b is only switching sound from the left and right speaker in the main room and nothing in the second room. I hope this helps.
  • asgamer Nov 24, 2008
    When I do this for thewires for the swecond room the sound still comes out the main room.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
You are describing a traditional "A-B" type of speaker setup, when what you need is a "main-remote" type of setup. A receiver which is capable of driving a main system (the surround one) and a remote, 2 channel system in another room. You would just have both sets of speakers in the same room. Many mid to high end surround receivers have this capability, though some don't have the needed amps for the remote system built in.
Thanks
Good luck
Posted on Nov 24, 2008
  • 905 Answers
What you need to do is take one speaker that you know works and try it on every output on the reciever
If the speaker works on all the outputs ( L & R , A & B ) on the reciever , then there is a wiring problem
If the speaker does not work on all the outputs , then there is an internal problem in the reciever
Posted on Nov 22, 2008
  • 71 Answers
Dear Asgamer,
please let me try to help. I have an older Yamaha receiver and comparing its conections to HTR-5930, I have noticed that there is a difference on the way Yamaha place the "plus" and "minus" plugs.
On HTR-5930 the wires are connected with the positive on top and negative bottom. On other receivers, negative and positive plugs are placed side-by-side.HTR-5930 Speaker A/B setup - e6cf110.jpg
The picture shows how speakers should be connected. "+" on top and "-" below, instead of "+" on the left and "-" on the right.
You don't have to set anything else to make it work, just press Speaker A or B switch to have your speakers working the way you want.
Hope you are satisfied, if not, please let us know.
Marcos
  • 67 Answers
My friend it i very simple disconnect all speaker wires. push in speaker a on your receiver then connect one speaker at a time and check room 1for sound eg channel a right on reciever until you get sound. now u have room 1 right ch to play now try the other speaker wires on channel a left until u find room 1 left ch system a and so the other two speaker wires should be for channel b or systen b or room 2 hope this helps you
    Scholar:
  • 181 Answers
If the whole speaker unit is working before in your old setop then its not the problem of the connection which you had made and nor the problem of the unit/device.but it is quite possible that the wires in the room which r set in the room from when it was constructed are getting cut somewhere or r loose internally .the wires needs to be checked internally by the electrician.as if the wires will not allow the speakers to play how can you get the proper settings as you want/require.
this wires are many times the culprit in this types of systems,and u go on changing the settings in the machine but nothing happens.just get this wires from the wall checked out and make it proper this will solve your problem.
thanks.
    Sergeant:
  • 276 Answers
Interchange the wires of speaker A in the sockets of speaker B.and wires of speaker B in the socket of speaker A.then check out.does the same problem.tyr inserting the wires in all the sockets 1 by 1.any 1 of the setting will definately work. and there is also a splitter system  which is having a very simple theory and works great for this types of system.and its not at all costly.also gives proper sound quality..
  • 689 Answers
Hi
Try the procedure from user's manual as indicated below
HTR-5930 Speaker A/B setup - 52dfd13.png
Please inform the outcome so we can find further solution upon your request
  • 10,594 Answers
Speaker A and B works in either way in this model.
Speaker A has only 2 speaker set connection where as Speaker B has 5.1 channel output.
Check below mentioned rear view of your Yamaha receiver.
HTR-5930 Speaker A/B setup - b56068d.jpg
  • Shahid Electronics
    Shahid Electronics Nov 23, 2008
    Seems speaker A and B settled in series when you select A+B option in your receiver.
  • Yamaha Master
  • 19,396 Answers
Are A and B single channels, or stereo connectors (eg, jack).
  • 370 Answers
It looks like on this model a and b speaker outputs can not be ran at once. You can always get a splitter from radio shack and just split a main speaker output and plug in both of them to that one output.
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I have a Yamaha HTR-5930 Home Theater Sys. Somehow, I've managed to lose my right channel when watching T.V. (dish network), but when my son plays with the XBox, he gets full surround stereo. Any ideas?
The XBox is probably hooked up separately to the amplifier, try cycling the inputs on the amplifier. If that doesn't work replace the cbale between your amplifier and tv.
Nov 19, 2010 | Yamaha HTR-5930 Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
Yamaha htr 5930
I think you have to adjust balance.
Page 22 of user's manual explains how to do it:
May 24, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR-5930 Receiver Logo
474 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
