Question about Yamaha KX-393 Cassette Deck Dual Cassette Deck
Problem with YAMAHA KX 400U cassette stereo tape deck
As the tape progresses the sound quality gradually deteriorates.best way to describe it-like the computer HAL in 2001 SPACE ODESSY when dave is turning it off
4 Suggested Answers
bobhifi
  • 635 Answers
SOURCE: I have a Kenwood KX
The flywheel belt would have broken or gone slack and fallen off the motor pulley. You can confirm this by opening the top and looking inside. If you can shake the machine holding it upside down the belt might even fall off.Replacing the belt is a tricky job. Its like putting back a bicycle chain except there is a metal plate behind the flywheel and your hand won't go there.
Posted on Mar 09, 2011
Testimonial: "Thanks, so much for your reply. Might you know of a repair place in NYC?"
  • 48 Answers
SOURCE: connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
To connect your cassette player to your receiver, you may have to use an RCA-type of plug (you know, the red & white plugs on both ends.
BOB (June 23rd '12 3:45am)
Posted on Jun 23, 2012
skywavebe
  • 1267 Answers
SOURCE: yamaha cassette deck k-300
There is no instruction on how to put belts in a deck other than a parts break down of kind of where they go. A seasoned Technician would not need this but a Service Manual is always the best place to start.
The Belt kit can be ordered from Marrs Communication and that will take the responsibility of sizing and then ordering the correct belts. The goo can be removed with denatued alcohol or Ammonia. I have always used alcohol and it is not a pleasant job for anyone.
Posted on Feb 21, 2013
How to tape from one deck to another?
Press the Dubbing A to B button. Put your blank tape in deck B. Press REC/PAUSE on deck B. Press Play on deck A
May 21, 2014 | Technics RS-TR272 Single Cassette Deck
Difference between a Yamaha KX 580 and a KX 580 SE cassette deck
Managed to find this blurb...
"The KX - 580SE is a refined model of the popular KX - 580, three time winner of ''What Hi Fi? Best Cassette Deck Award''. The KX - 580SE is a special edition which is UK specified. This cassette deck features CD to tape synchronized record start, timer record / play, new audiophile components in both the dolby and audio output stages, two - motor stable transport, Dolby HX pro dynamic bias servo, auto tape tuning and improved power supply."
Feb 11, 2014 | Audio Players & Recorders
Hi, I'm digitising my old cassettes. I have a
Just connect the line outputs from the tape deck to the line input of the computer using a dual RCA to mini stereo adapter if necessary. Your processing software will correct any deficiencies and produce satisfactory results. Be sure to copy the original tape information before dumping the old tape; otherwise you will have a "mystery" CD
Sep 08, 2013 | Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
Connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
Apr 20, 2012 | Yamaha KX 390 Stereo Cassette Deck Single...
The tape runs a bit fast on play mode. Is there an adjustment for this or is it a board or motor problem.
Sometimes the motor has a control pot on the top. You might find it under a label, it will be only a small circular hole.
Otherwise trace the wires from the motor back to the PC board, you should see a Pot for the speed there.
Please bear in mind that if it is a second hand machine somebody could have replaced the motor with the wrong type.
Nov 23, 2009 | Yamaha KX 390 Stereo Cassette Deck Single...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Downloading an instruction manual for the K-700 Cassette Deck
Make sure you have the correct model # and go to the Yamaha web site. There is no K-700 but there is a K-720 (I have this tape deck).
http://www.yamaha.co.jp/manual/english/search.php?div=emi
May 06, 2009 | Audio Players & Recorders
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
DECK B PROBLEM ON RARELY USED MACHINE
if the heads are getting jammed in the up position it may be a failing capstan belt in the transport not disengaging the transport properly. replace the capstan belt. If one has failed both will probably be bad.
Oct 06, 2007 | Yamaha KX-W321 Single Cassette Deck
Yamaha KX-393 Cassette Deck Dual Cassette Deck Logo
377 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
