Question about Foxconn 865A01-PE-6EKRS Motherboard
Motherboard won't start properly
Hi, i'm having a problem with this motherboard. when i'm going to power on my comp it won't starts at first time. i have to plug and unplug it's power cable and switch on for several times. it likes as it can't start as smth prevents it to start on.cable and power are OK. but after successful power on i can switch on and off it, no problem. everyday morning i come across with this problem. plz help!
There is problem with your SMPS capacitor .
replace the SMPS the problem will solve.
wasim
Posted on Feb 29, 2008
  • 20 Answers
It seems thr is some prblm with ur MB capacitor or ur power cable cn also be faulty check ur power cable with another computer.. if it is working go to a gud computer repairing store n tell hm to check ur motherboard against bad power supply..
Posted on Feb 25, 2008
  • 40 Answers
Check PowerSupplyUnit and carefully examine motherboard for bad capasitors: badcaps.com
Posted on May 23, 2007
I have teouble to start my comp i got one long tone and followed by three short tones , can you help me whats wrong to my comp. Mod : GA-686LX3
Remove RAM, clean slots by blowing air, fix RAM back and check whether it is properly seated.Check whether all the wires connected to the motherboard are fixed properly.
Sep 03, 2010 | Gigabyte 440LX (GA-686LX3) Motherboard
I have asus M2N68 am-plus mother board. When I switch on the comp. It takes about 10 seconds to show the boot screen. Want to know the reason behind this
hi,
it could be something is slightly loosen up in there. to check your load up time, go to start then right-click on my computer. click on properties. there you will see advance system settings, click on its tab.on the startup and recovery category, click on settings. there you will see how much time does your pc takes to load. if you can open up your pc and make sure that everything is hooked up properly, then switch it back on.
Jun 15, 2010 | ASUS M2N68-AM SE2 Motherboard
I have pcchips m955g motherboard, comp reboots during
If the computer keeps rebooting when you first start it up it is quite possible that the hard drive is broken. It keeps looking for the start up boot sector, but it's broken so it keeps trying again..and again...and well you know.
Hank
Nov 30, 2009 | Computers & Internet
Doesn´t start
Have you tried "Last known good configuration"?
May 30, 2009 | MSI K9N GM2-FID (7252030K9NGM2FID)...
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
When i start comp first screen says video bios shadowed and somthing else bios shadowed the machine wont start beyoned safemode screen can't even reinstall windows please help
How old is the motherboard? Open the case and make sure that all cables are connected properly and that the memory sticks are not loose.
If its an old mobo then the battery on the motherboard may be dead and needs replacing - this is what keeps all settings.
Going into bios and resetting to factory conditions may get you back into windows until the next time you turn off again.
Apr 19, 2009 | HP Computers & Internet
E1505
Start by checking the power supply with an ohm meter for the proper output. Anything higher or low than one volt means the supply is faulty and will need replaced. This could also be a battery issue, if a fail safe in the battery has engaged. Try removing the battery and see if it works properly on the supply only, if so, then the battery will need replaced. Also, remove the memory, and try each chip one at a time in each slot. A faulty memory chip pr slot can have this effect. If these three check good, then I'm afraid the problem is with the power management system on the motherboard, and unfortunately the motherboard will have to be replaced. Since the light is flashing, this indicates a code. You can find a light and sound codes list for your machine at Dell's support site. This may help in identifying the exact problem area.
Aug 17, 2008 | Dell Inspiron E1505 Notebook
My computer it wont start!
the three beeps mean there is a problem with your RAM module or modules either check that they have been installed properly or if they have then maybe replace it or them because they/it could be faulty. thanks
Jun 01, 2008 | Lenovo Computers & Internet
Add-on
Hi im Joan Hall.I have a suggestion.Please check your IDE Cables.When u reboot your computer it should say detecting IDE Cables.If it beeps that usally means that your computer has an error.See if its not the IDE Cables because they will cause your computer to beep and not boot up right.
Dec 10, 2006 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Foxconn 865A01-PE-6EKRS Motherboard Logo
200 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
