Question about Insignia Digital-to-Analog Converter for Analog TVs
HDTV converter box only brings in 3 channels
My 2 perfectly good TVs bring in 9 channels with a stationary antenna in my attic. With the converter box I get 3 channels. Tried hooking box up 3 times, once on TV with DVD, VCR hooked up, twice with just the TV. I really can not afford one, even less two, new TVs. The digital flat antenna I purchased still only gives me 3 channels. Cable TV is just another bill added to my increasing load of bills. What are my options?
  • 5 more comments
  • bowincle Dec 08, 2008
    Totally agree. I was happy with my few channels I was getting before. Yes, with the new box they do come in much clearer but, that is if I can actualy get the picture to not skip in and out and tolerate the sound of only partial sentences being heard. Is there a way to get these new gadgets to actually work?
  • bbremodeling Dec 30, 2008
    Yes we have the same problem. Hooking up the HD converter box gives us a weak signal and less channels. Please contact with a solution.
    Thanks
  • liljayman Jan 18, 2009
    I have the same probem. The channels do come in clearer, however there are fewer of them. It's very frustrating. On Feb. 17th, will we get more channels, or is this how it's going to be for now in?? Someone please help!
  • Anonymous Mar 05, 2009
    i only receive 3 channels fox, kcoy,and cw.
  • jkj5 Mar 09, 2009
    I cant get but one channel out the five i was receiving. very frustrating
  • johnriddell Apr 27, 2009
    All I get are the Jesus Channels and I have tried 3 different antenna I have to idea what to do I this this DTV is a bunch of ****
  • Anonymous May 06, 2009
    I dont get but 3 channels and I bought 2 converter boxes thinking i would save money. People that live only 5 miles away get 19 channels in all. What can i do to get that type of service. DTV is FRustrating so far.
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Posted on Nov 24, 2008
I have no cable i get all channels excep CBS in chicago tried scanning no luck
Amazon has a great antenna that can bring in stations from as far as 150 miles away (terrain is a factor). Do not get these Window or Wall antennas as they are junk, just an outdoor type. I use one indoors, in my viewing room, however it can be mounted in the attic. The unit is a VILSO product, comes with a rotator, antenna booster, 50Ft cable, weatherproof antenna, control box and a hand remote, all for under $40.00. Check it out.
Jan 14, 2018 | Televison & Video
I havce installed the digital converter box and everything seems to be okey. I get the menu page, and do a channel scan, which brings up no channels. With the converter turned off, I get a cable signal...
1. If you are using the composite video output, double check that your antenna is connected to the converter's antenna input and not the output.
2. If you are in a remote area that gets signals through translators, there might not be any digital signals to receive.
Is the antenna connected to the input of the converter box? There should be a screw on connector on the back, the antenna connects there.
If you have the antenna connected properly, have set the conveter to scan for channels, and you were able to watch TV with the rabbit ears before you got the box, the box may be defective....!!
Thank you!!!
PLease post back for further assistance..
Regards!!...
Jul 31, 2008 | RCA Televison & Video
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
With converter box only receive 2-3 channel
They have powered antennas that give you more stations. I added a HD antenna I bought off ebay for 19 dollars and I get 10 stations. Please give me good rating It means a lot to me.
Jul 05, 2009 | Insignia Digital-to-Analog Converter for...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
Nhens convertor box www.dsconter.com
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Aug 29, 2008 | Philips Magnavox 20MT133S 20" TV
Dtv box
the box broadcasts through channel 3 thus you have to set your tv to channel 3 to pick up the signal. There is a menu to use once you get a singal to pick up the channels. You may also want to call the 1800 number on the back of the remote, they will wallk you through the problem.
Jun 16, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
710 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
