Question about HP Compaq Business d530 Small Form Factor PC Desktop
Want fix it
Wiring a dvd with sata on pc s.no. sr1803wm with ide
    Problem Solver:
  • 4 Answers
You would require a SATA extention card if you motherboard does not support sata currently
Posted on Dec 27, 2008
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
My dvd's and cd's will not play from my e drive. What's the problem and how can i fix it?
you can order a new DVD rom from newegg.com which cost less than $20.
it is easy to remove the dvd rom drive from your machine.
just open the case, unscrew the screws holding the dvd rom in and unplug the cables.
you need to find out whether you have a IDE DVDROM or SATA DVDROM before purchasing your new DVD rom drive.
IDE looks like a ribbin flat wide cable.
SATA is a skinny small cable.
Mar 10, 2011 | E-Machines eMachines Desktop PC
I want to install a CD/DVD RW drive. This is in addition to the installed CD/DVD already in place. The new drive has a SATA connection on the back, and the only available connector is an IDE connector....
There are IDE to SATA adapters and cables, such as this one linked below. IDE to SATA Adapter
You would simply plug this adapter into the available IDE connection on your motherboard, then use the SATA data and power cable to connect from the adapter to the CD/DVD drive. You can look around online for similar products, but they should get the job done!
Mar 05, 2011 | HP (REFURB) HP XW4200 XPP P4 3.4GHZ 80GB...
HI i Have a acer aspire T-180 .Am looking at purchasing a dvd Writer fr it but am asked if its Sata ot Idu do you know which is compatible ?.thanks
The dvd rom will IDE not sata, it will be possible to put a sata dvd-r in the pc but you will have to make sure you have the right powwer connector on the power pack for it, your best bet would be to use an IDE dvd-r and add it to the slave connector on the IDE cable already in the pc. hope this helps.
Aug 13, 2010 | Acer Aspireā„¢ T180 PC Desktop
What type of dvd drive can I install on emachine w3118 IDE or SATA?
This computer has a IDE and SATA port inside it so you can either install a IDE or SATA drive on it, but what it came per built is a IDE drive.
May 19, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
Will an IDE DVD Burner work on my Acer Aspire E380 desktop. The hard drive is a SATA but the burner looks like an IDE and has belt cables. I need to replace my DVD burner and not sure what type of burner...
Yes, all you need is a IDE (Pata) to IDE (Sata) converter.
If you're replacing it, just make sure you get one with the correct interface, judging by what you sat SATA.
Mar 13, 2010 | Acer Aspire E380-ED422A PC Desktop
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
HP Compaq Business d530 Small Form Factor PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
