E: 0145-0001 That code is on the printers screen. Should that clear it off of the printer screen?
Erore code
You can try to clear it with " press the yellow clear botton, then the numbers 1 - 0 -7 , then press and hold the red clear stop botton, till the screen changes... Then turn the MAIN POWER switch OFF & then back ON. If that will not clear the code, then let us know what the error code is , that is displayed on the display screen.... Good Luck
May 24, 2012 | Ricoh Aficio 450 Copier
Our Gestetner DSM635 jams every time we try to staple copies. Researching this issue, I saw that we need to initialize the staples by going into the Tools screen. However, when I try to do this, that...
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving
Jan 26, 2011 | Gestetner DSm635 Copier
SIR PRINTER SCREEN SHOWING DOOR OPNE, CLEAR
sir printer screen showing door open, clear cartrdge jam and then press enter
Jan 18, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
I have functional problem displayed, how can I solve this without paying for a service call
You can try to clear the code by pressing the yellow "clear modes" key, 1, 0, 7, then press and hold the red clear/stop key. Wait for the screen to change, then turn the machine off with the red rocker switch on the left side of the machine, turn back on, and see if that clears the code. If not, let me know what the code is for further assistance.
Oct 22, 2009 | Ricoh Aficio 180 Laser Printer
Error code 09,037.45:35260
This code has to do with the ink loader. Check to see if the ink is stuck in the loader tray, broken inks, or incorrect type ink. Then go to the diagnostics screen and run CLEAR ISC FAULT to clear the error.
Apr 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Oct 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
How do i clear the code on the display screen?
The only way to clear it is to replace the fuser rollers or the thermistor.  Clear code isn't available for override.
Sep 10, 2008 | Office Equipment & Supplies
Error code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
166 people viewed this question
jasbo
jasbo
