Question about Linksys Wireless-G Broadband Router
Can not remember or find network security key
Trying to set up a wireless printer; everything else passed except
my WEP security key.
  • 132 Answers
You may need to access the router's setup page to check the security key or the network key you have set up to the router. To do this:
  1. Launch IE and type on the address field using a computer that is wired to the router. It is the default IP address of the router. It will then ask for a username and password. By default, there is no username and the password is admin.
  2. Once you're in the router's user Interface, click Wireless tab. There is a sub-tab under Wireless which is called Wireless Security. Click on it.
  3. There you will find the type of wireless security you have enabled in your router as well as the network key.
Hope this helps!
Posted on Nov 22, 2008
I am trying to find what my wep key is but i cant
The WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 29, 2011 | Computers & Internet
I am trying to connect my wireless printer to the router, but when it comes to the WEP code, the one I have does not work. Is there a way to reset the WEP code?
Hi glenncj,
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
You can also reset the router by pressing the Reset button at the back of it for 15-30 seconds using a Pen and a Paper Clip.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
I forgot my security code
Are you setting up this printer on wireless network and you dont remember the WEP key its asking to you enter ? ( HP Printers do not have Security Code )
IF you are Setting the printer on wireless network and forgotton your network Security key, download the HP network diagnostic utility and Run the program, it will provide you with the network details and the key
Jun 25, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Need wep key i am trying to install a wireless printer and have no idea what the wep key is for my router. how do i find this out? thanks
Go to your wireless router software, log in, and click on the security setting section. Create a WEP key by providing a secret code or password that restricts access to the network.
It can be anything ya want, as long as it is same at "Both ends" IE: when ya try to acess, connect to the Network/Router, from say a lappy, ya gonna get asked for ya" WEP Key" < READ "Password".. So ya type in the number/password ya first chose and put into the router. You generally only have to do this once and it will remember the setting for future access.
Jan 24, 2010 | D-Link DIR-615 Wireless Router
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
Linksys Wireless-G Broadband Router Logo
80 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
