Question about Toshiba Satellite M55-S135 Notebook
Wireless not working
My daughter was recently given a used Toshiba Satellite A65-S126 laptop. It connected wirelessly to my Linksys 802.11 wireless router with no problem. Now it's not connecting. I don't think the laptop is loioking for the connection. how can I check it.
Thnaks I have owned a Toshiba Satellite A65-S1064 for about 5 years and over the past few months my wireless has been rendered useless.
-System restore did not resolve the issue
-Update driver (from Disk or internet) does nothing as there is not a newer compatible version for my pc. It just pulls the same driver that is installed.
-Re-Image of the hard drive to the Toshiba factory image does not resolve the issue.
-After installing all patches and XP SP2 (factory image had XP SP1) issue not resolved.
The closest I got is to enter the WEP key but then it was looking for certification. Still did not work and after attempting to reboot the hardware is now missing from Device Manager.
Any other ideas are appreciated!
  • brpker Nov 29, 2008
    My wireless installation needs the wireless switch turned on.How do I do this? ThanksBob
  • jake04124 Dec 09, 2008
    My ORIGINAL POST was mixed with another. Here is the problem I posted:
  • 55 Answers
First check whether the wireless switch on ur laptop is turned ON orn't.it should be kept always on
Posted on Nov 22, 2008
  • sarbadadinu Dec 12, 2008
    it will be on the front sice of the laptop generally by moving the switch an orange indicator glows
Location of wireless communication switch on Toshiba Satellite Series M55 laptop.
No longer have user manual
Posted on Dec 08, 2008
I am not able to connect to my wireless network on this computer. The icon show and the wireless connection shows up in the list but it will not connect to it. I have attempted to have windows repair the...
If you recently purchased your notebook, wifi may not be enabled. There is typically a switch on the side to enable the wifi card. Locate that and make sure it is on. Also Fn+F8 should activate and deactivate your wifi. Hope that helps.
Dec 10, 2010 | Toshiba Satellite A65-S126 Notebook
MY laptop has the light for wireless lan but cant see the drivers or device.ur advice pliz
You might want to try installing the following...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713852&rpn=PSA60U&modelFilter=A65-S126&selCategory=2756709&selFamily=1073768663#
Aug 06, 2010 | Toshiba Satellite A65-S126 Notebook
Satellite A65-S126 (PSA60U02K015) PC Notebook: I cant get the wireless connection to work?...
There's a little slide switch on the side of the laptops body, on the right hand side on mine. Make certain that it's on the "On" position. I had the same problem, and i found out that i had turned the switch off.
--- dharmabum59 ---
May 17, 2010 | Toshiba Satellite A65-S126 Notebook
I cant get my lap 2003 laptop to connect to the wireless inter-net and the cd/dvd drive door will not open
Check if your wi-fi is enabled. if it is, then it should have a remark that WIRELESS NETWORK is available and have a link to CONNECT. then you will be prompted for a password if connection is encrypted.
Your cd/dvd door might have stuck up for long time of not using it. Gently push it while pressing the eject button. It should eject manually.
Regards!
Jul 15, 2009 | Toshiba Satellite A65-S126 Notebook
Can´t get an IP valid address on a Toshiba a65 with a Realtek LAN NIC Card that shows well installed, working, perfect a properly reconignized within the system, although there´s no error showing...
Power off your wireless router for 30 secs. and power it up again wait till all the LED are on and functioninh normally.
THEN
Reboot your laptop OR
Right click on the wireless icon and click on Repair - this will force the wireless card to obtain a new IP address from the wireless router.
May 02, 2009 | Toshiba Satellite A65-S126 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Hard drive wipe issue
It appears you have some kind of web access so I woulld start at the Toshiba site to look for drivers and download to an optical disk for installation into your laptop.
Most public libraries have terminals and on request, on your cost, they will burn a CD for you or allow you to burn one on your own blank.
Those drivers might also be already on whatever Toshiba disks supplied with the system.
Aug 03, 2008 | Toshiba Satellite A65-S126 Notebook
Wireless network
This link will take you to the drivers its on the second page DRIVER LAN WIFI.
Mar 21, 2008 | Toshiba Satellite A65-S126 Notebook
Make sure the wireless power switch on the right side (next to the USB port) is turned on.
Jan 13, 2008 | Toshiba Satellite A65-S1065 Notebook
Toshiba Satellite M55-S135 Notebook Logo
580 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
