When i hook up my comp the monitor stays black...whats going on?
My tower and my monitor both power on but the monitor stays black... if i unplug the cable cord the monitor then comes on for a sec saying for me to check the cable connection but as soon as i connect it the screen goes black again. is my comp broken? Please help!!!
  • bryanjm Nov 22, 2008
    my tower and my monitor both power on but the monitor stays black... if i unplug the cable cord the monitor then comes on for a sec saying for me to check the cable connection but as soon as i connect it the screen goes black again. is my comp broken? Please help!!!
  • 153 Answers
Try remove your VGA card and reinsert and test. And if the problem persist then test your monitor to the other PCs and if it displays then it could be the card is bad or the monito's resolution was ajusted causing to be uncompatible for your PCs resolution.
Posted on Dec 02, 2008
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Hooked up New Hp comp (tower only) to slightly new HP2007 monitor but there is no sound.Could you give me an idea of what I missed?
Make sure the audio cable supplied with the monitor is connected correctly. Make sure it is connected to the green (speaker out) jack at the back of tower and the same green (audio in) jack on the monitor. Also make sure the volume on both your PC and monitor is turned up and not muted
Dec 03, 2010 | HP W2007 LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Monitor directly enter into power afe mode wen we
turn off the cop and unplug all the cables and open the comp tower and remove all memory chip and turn on the comp by plugging just the power cable and leave the comp on for 2-3 min and the comp will beep and thn turn off the cop and pull the power out and put the memoy chips back in the comp and plug all the cables asnd then turn on the comp anf the issue resolved le me know if any problems at tauseef.razzaq@yahoo.com
Memory Installation Guidelines
Sep 18, 2009 | Computers & Internet
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
Dell Computer Monitor - Black Screen
If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
Please vote if this helps.
nLinked
Computer Support Services
Jun 08, 2009 | Dell E193FP 19" LCD Monitor
The computer does nothing its stuck in test mode
I think your PC got static build up just leave the PC for some hours and try pluging back the power cord.
Nov 19, 2008 | E-Machines eMachines Desktop PC
Monitor just black
I would guess the capacitors are bulging or leaking. It can be repaired if you are handy with a soldering iron. Good Luck.
Oct 01, 2008 | Liquid Video A170E101 Monitor
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
