Question about Panasonic NN-S567BA/WA/LA Microwave Oven
Inside light is burned out.
Panasonic 1997 microwave. Model # NN-S567BAS
  • Panasonic Master
  • 9,125 Answers
The Sears parts Web site has a ton of helpful info on this model, including disassrembly help. Looks like a lot of the actual service manual online! You can also order parts there. Enter your whole model number NN-S567BAS at http://www3.sears.com/ (the 3 is correct) Terrific!
Posted on Dec 27, 2006
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My microwave nn-994s smell burning and is working 50% power panasonic model nn-994s
Due to the lethal voltages used and produced in inverter-based, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 19, 2009 | Panasonic Microwave Ovens
Panasonic Model #NN7524A Microwave bulb replacement help
microwave---NN-S335 , 800W Plate exploded , Where can I get another ? From C Carver Feb. 23 , 2009 Thanks
Feb 25, 2009 | Panasonic Microwave Ovens
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
I have a Panasonic Inverter Microwave Model #NN-H665WF and my daughter accidently put a whisk inside a bowl inside the machine and turned it on. It left a burn mark on the inside. Is the microwave still...
Yes, but the burned mark should be cleaned and if necessary sanded smooth and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 25, 2008 | Panasonic Microwave Ovens
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-S567BAS Receiving power, No Waves
I would still suspect the top door switch. You would need to operate the switch to see if it clicks both ways and ultimately a test with a meter is required. If you don't have a meter, you can connect wires to a battery and a flashlight bulb, etc., and use that as a continuity tester. On the door switch, COM is common, NO is normally open, and NC (if present) is normally closed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find thew whole service manual (in sections) and order parts by entering your model number (without the dash) here: http://www3.sears.com If it's not the door switch, I would suspect the control circuit board (the one behind tghe keypad) and we repair these nationwide for only $39.95.
May 31, 2007 | Panasonic NN-S431WL 1000 Watts Microwave...
Microwave Ovens Logo
296 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
