Question about Sony Walkman NWZ-S616F MP3 Player
Library Error - all songs are gone - Help !
When I disconnect the mp3 from the computer it displays the message 'Library Error Encountered', then when I select the Music Library from the Home screen it displays the message 'No songs available for playback'. What did I do wrong and how do I get this thing working again ? Thanks for any help you can give me.
  • 1 more comment
  • Anonymous Apr 06, 2009
    I have exactly the same problem, the entire device has been wiped, and I can no longer sync files to it! I have reset it but nothing happens.
  • Anonymous Apr 09, 2009
    SOLUTION!!!
    I know how to fix it, go on settings, then common settings and click on format. It will totally wipe the device, including the corrupted file. Try syncing music again and hopefully it should work!
SOURCE: When I go to listen to my mp4, it says
I started to have the same problem today and was also getting a "Library Error Encountered...." message. I was able to resolve it by Formatting my player. I lost all my data and settings but now I can put music on it again. To format your player go to the Home menu-Settings-Common Settings-Format
Posted on Feb 15, 2010
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
Posted on Feb 08, 2008
coldtoon
  • 51 Answers
SOURCE: I cannot add music from from my itunes library to my Sansa m230?
itunes puts drm on music get that off and your f ree to go
Posted on Oct 02, 2008
  • 22 Answers
SOURCE: walkman isn't working
which software did you use to transfer files and to which folder did you put them in??
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: album art does not transfer with music on my sandisk mp3 player
Go to the sytem Settings menu and go to this option:
Display Art in Lists
Enabling this feature displays a small image of the song album cover, audiobook
cover, and photos when scrolling through list of these items.
1. Scroll down to Display Art in Lists and select it.
2. Use thumbwheel to switch between On (enable) and Off (disable).
If changing this option to enable fials to resolve the issue, the solution is a bit painful: You will have to manually add the artwork to each single song within an album in Windows Media Player 11, delete the song that is missing the artwork off your sansa, and re-add the songs again after you are done manually ediitng the artwork.
Manually add album art (WMP 11)
1. Run WMP.
2. Click Library on the top bar.
3. Select and right-click the file(s) you wish to update and select Advanced Tag Editor.
4. Click the Picture tab, then click Add.
5. Navigate to the image you wish to use for album art then click Open.
6. Click Apply then OK.
Posted on Mar 25, 2009
I don't know how to delete songs from my MP3 player....
Follow the below mentioned steps :
Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
3.
You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4.
After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click "OK." The song will be deleted. The change will be displayed within the library onscreen.
5.
When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
In case of any additional help please revert back.
Jun 12, 2011 | Televison & Video
When I go to listen to my mp4, it says "No songs available for playback. Please connect to complaint software or device and transfer songs". It will no longer sync with my computer and I cannot listen to...
Nov 19, 2009 | Sony Walkman NWZ-A826 Digital Media Player
How do I delete tunes?
1. Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
2. Click on the "Sync" tab and the library that is on your MP3 player will be displayed.
3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click "OK." The song will be deleted. The change will be displayed within the library onscreen.
5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
Oct 28, 2009 | Sony Walkman NWZ-B135 MP3 Player
HOW DO i DELETE WHATS ON MY WALKMAN AND i CAN'T OR DON'T KNOW HOW TO DOWNLOAD MUSIC
Oct 24, 2009 | Sony NWZ-E438F Digital Media Player
How do I delete songs off of my sony walkman 4GB
2. Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
Oct 05, 2009 | Sony Network Walkman NW-E005 MP3 Player
Ok so I have a coby mp3 player and the songs are
Ok there are 2 Solutions that can fix this:
First:
Or if that does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Coby's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 03, 2009 | Coby MPC-848 MP3 Player
I just purchased a RCA flash mp3 player. I
Oct 01, 2009 | SanDisk Sansa c140 MP3 Player
Trying to delete song off my sony mp3 walkman
try this
Jan 11, 2009 | Sony Walkman NW-A808 MP3 Player
ITunes to IPod
It sounds like you have your IPOD set to automatically sync to your itunes library instead of being set to manually select the songs. If you have it set to automatically sync then anytime you plug your ipod in with itunes open then only the songs that are in your Itunes library will be on your IPOD after you disconnect it from the computer. If you would have set it to manually sync then you would have had to choose which songs to put on your IPOD and also which to take off. If you had it set to automatically sync then I am sorry to inform you, but your songs are gone from your IPOD (and if you have it set to delete the song from the computer as well as the library then the song is gone from your laptop too)
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
My mp3 player wont turn on and my songs are gone
First, try uninstalling and reinstalling the software.
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Sep 04, 2006 | Philips SA-177 (512 MB) MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
699 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
