Question about BenQ FP71E 17" LCD Monitor
Monitor menu opens up on its own
I own a BENQ FP7IE, and recently the main menu for the monitor has been opening on its own. It opens about every 5 minutes. Have any suggestions?
  • Anonymous Mar 13, 2008
    I own a BENQ FP7IE, and recently the main menu for the monitor has been opening on its own. It happens every few minutes and disapper.
    Please help
    Champion:
  • 220 Answers
Front panel switches are defective.
Contact BenQ,Normally company offers 3 year warranty.
Samir
Posted on Mar 10, 2008
The menu is popping all the time, help me to solve this please its driving me crazy!
Hello Nirel,
I'm assuming you're talking about the menu on the monitor itself. Is the button jammed for some reason forcing the menu to open?
John
Jun 25, 2014 | BenQ FP71G 17" LCD Monitor
My monitor keeps opening monitor menu and keeps auto adjusting
As you have already used a cleaner spray, this is a sign that the monitor is on its' way out. I had one that went the same way.
Apr 13, 2013 | Computers & Internet
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
Do you know how to open a benq fp91g+ monitor?
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=BENQ&megnev2=FP91&kategoria=&kat2=all
Most of the time you will use flat blade screw driver, starting at the bottom edge to pry open the case then work your way around, also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
BenQ makes monitors for DELL and HP.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | BenQ FP91G+ Monitor
Problem with controler
The problem is defective keys/switches of front key PCB.You need to replace this key PCB or Individual keys.
Normally Benq Offers a 3 yr warranty Try contacting BenQ.
Please rate the solution and provide feedback.
Samir
May 15, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
How to take apart a benq fp731 lcd monitor
You remove the 5 screws behind and using a plastic card inserted between the front and back plastic frames gently prise it open.
Careful!!! High voltages inside.
Feb 21, 2008 | BenQ FP731 17" LCD Monitor
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
262 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
