Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
LOads generic driver
I have a Dell Dimension 8400 with a 1704FPTt monitor. A year ago I lost my hard drive (? don't know why) but was able to load the Dell video driver onto the replacement drive, and everything worked well, but then, last April, my second drive failed (?????) and now I cannot even TRY to load the video driver. When I go to the Display properties/Settings/Advanced/Monitor/ the Monitor Properties is grayed out so there's no way I know of to load the Dell driver.
My monitor "snaps" when I scroll up and down, and I cannot use my favorite "Rotate" function.
Any ideas?
  • Jonathan James
    Jonathan James Mar 05, 2009
    Unfortunately the driver for my monitor, which I did get from Dell, didn't recognize the card I have, which also came from Dell. It didn't load. I don't know why . . . I tried several others from Dell, too, as well as from Drivers.com, etc. It wasn't until I went to the MS site that I successfully got a driver loaded that works . . . and showed me that I didn't have to replace my video card after all. That was a relief.
    Even so, my monitor still blanks out (goes black, after about 20 minutes, but if I give it a sharp rap with my fingers, turn it off, and then turn it back on, it'll sometimes run for hours ! MOST of the time. Strange behavior.
    Thanks anyway.
    JLJames
    Scholar:
  • 81 Answers
You can download display drivers from the support website use the link enter the system service tag select the operati9ng system and download the latest video drivers .
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn.
enjoy
Posted on Mar 30, 2010
  • 77 Answers
Its not the monitor that needs the driver, its the video installed on your computer, can you tell me the video card installed? you might need to use the resouce cd that came along with your computer and then look under video driver and the one that has a check mark is the one thats for your computer, but if you have an add in card, you should get a separate cd for it and thats the one that you can use. the video options is grayed out because the video driver wasnt installed properly. if you already know whats the video card on your computer, you can install the driver from here. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_8400
under video there are 12 options, just look for the name of your video card and install it. thaT SHOULD WORK ALREADY.
Posted on Sep 11, 2009
    President:
  • 2,653 Answers
All of the software drivers for your machine can be found by using Dell's support page.
Here's a direct link.
A lot of experts here will just give you a direct link to the file you're looking for. Although this is great for an end user since all you've got to do is click the link, it's not going to help you long term.
What I purpose is you learn how to find software drivers yourself.
This will decrease the need to relay on others for help and will ultimately make your experience with computers much more pleasurable.
If you're still having trouble just reply to this thread and I will respond immediately.
Also please don't forget to rate my solution FixYa, it helps me, help you.
Thanks!
Posted on Mar 04, 2009
Moving HDD from Dell Dimension 4300 to 4600 but b4 loading WinXP keeps going back to WinXp choice screen
haveu formmated your disk & installed an operating system ie Win7/Xp it seems u have not got an operating system.
Apr 25, 2012 | Dell Dimension 4600 PC Desktop
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Dell dimension 8100 wont start windows at times
It could be a virus, run antivirus scans, or could be your drive cables, Or even an Occaision glitch. Even perfectly running machine have glitches.
Jul 15, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Dell dimension 4300s want to move hard drive to a new machine
You can move it but you have to remember that its going to have different hardware then your dell 4300 so it might require you to install drivers for the hardware that windows XP pro can't recognize. Keep that in mind so as long as you know where to go to get drivers for the hardware in that other machine, it won't be a problem.
Mar 02, 2009 | Dell Dimension 4300S Convertible...
Dell dimension 2400 desktop-2003 model
Michael
Looks like a hard drive failure- simple as that. You can try a number of things but as far as my experiance goes the hard drive is dead. You either need a new hard drive or better a new computer.
Dont want to give false hopes...
regards
keshey
Feb 16, 2009 | Dell Dimension 2400 PC Desktop
New Hard Drive Dell Dimension 3000
Theres a problem with your driver installation.your computer is newly formated and wiyh a new harddrive but still theres a problem.check your monitor if it can support up 1024/768 pixel so that you can adjust your screen resolution to a smaller icons.also check your vga.and rollback device driver for sound device.
May 29, 2008 | Dell Dimension 3000 PC Desktop
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
139 people viewed this question
Alun Cox
