Question about Basic Remote Vehicle Alarm System
Bulldog remote starter will not disengage
Tryed tachless mode and it still keeps starter engaged until I hit stop button or step on brake
Had the same problem with my bulldos remote starter, got a different brand and no more problem.
Posted on Dec 31, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Put an rs82 bulldog remote starter in my 2005 town and country, and after 11 seconds it stops and re engages the remote starter and stops after 11 seconds and stops completely
It sounds like the RS82 is not getting a proper tach signal. If you are using tachless mode, the 12 volt constants may not be providing the desired signal. Recheck your connections to ensure that they are solid. The high amperage wires should be soldered. You will need to connect the tach wire if the connections are good. The tach wire can be connected to the negative side of the ignition coil's blue/brown wire or the blue/green wire at the PCM or you can use any one of the uncommon colored wire at a fuel injector.
Oct 10, 2012 | Remote Starter with Keyless Entry
When I plug in the red power wires, the module starts clicking
IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
Dec 27, 2010 | Remote Starter with Keyless Entry
When i juck the power, parking lights blink
Oct 23, 2010 | Remote Starter with Keyless Entry
After installing a rs1100 remote starter the vehicle keeps giving several error codes (which I reset but they keep coming back). I'm not sure if the ignition (white) and the starter crank (orange w/black)...
IF YOUR REMOTE STARTER IS CLICKING AND/OR FLASHING THE PARKING LIGHTS AND IS NOT RESPONDING TO THE REMOTE, IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
Other details can find in the Bulldogsecurity ModelsRS1100_1100E_114
TY for use Fixya, good luck(remember rated this help).
Mar 02, 2010 | Remote Starter with Keyless Entry
I bought a used truck with a bulldog remote starter in it but the guy has it set to start when it reaches a -10. I want to reset so only starts when I hit the button. The key fob looks alot like the rs...
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
Feb 01, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Module in Initialization mode
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Jan 10, 2010 | Remote Starter with Keyless Entry
I have a 2004 tacoma. Remote starter doesn't work. Dash lights on right side of the dash are dim. Remote starter was pro installed 4 years ago. Any ideas? Thanks
look under dash for the unit, remove the 2 fuses in red jackets wait 2 minute then replace fuses
Dec 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Model rs1100 when i completed the wireing and pluged in the red +wires all i get is a clicking noise
The unit is in "safety mode" . To exit safety mode on 4 Button Remote, ground the hood pin switch if installed, press and hold the brake and push any button on the remote the clicking should stop. Take the ground off the hood pin switch and release the brake, then test the remote.
Nov 18, 2009 | Bulldog RS-1100/GM-12 Remote Starter &...
Basic Remote Vehicle Alarm System Logo
369 people viewed this question
Top Bulldog Vehicle Parts & Accessories Experts
john h
DrBogo
Level 1 Expert
vtec
Are you a Bulldog Vehicle Part and Accessory Expert? Answer questions, earn points and help others
