Question about Kenmore 63942 Dryer
Need to open the top to find the fuse
How do i open my dryer model #11060992990 to get to the fuse
    New Friend:
  • 128 Answers
Two clips in the front - use a six in one tools to pop it loose
Posted on Nov 22, 2008
Where is the thermal fuse located on this dryer? please
Hello Leslie
I don't know what is the brand of you dryer. I will make you a preference this brand.
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. To access the thermal fuse you will need to open the dryer from the top. Though it may sound a bit daunting, opening the top of the dryer to reveal its inner workings is surprisingly simple. To open the dryer top you will need a flat-head screwdriver, putty knife or similar tool. Insert the screwdriver or putty knife underneath the dryer's top panel. Slide the putty knife along the bottom of the panel until you locate the two clips that hold it in place. These clips are usually located about four inches in from either side of the top dryer panel. Apply pressure to the clips to release them. Once the clips have been released, lift up the top panel and use the supports to keep it upright. Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing. The thermal fuse will be located next to the heating element housing. Look for a white strip with two wires connected to it and you've located the thermal fuse in your GE dryer.
Best Regards
Neciforo Llanto
Oct 01, 2013 | GE Profile DPSB620GCWW Gas Dryer
Kenmore Elite model #11060992990, has suddenly gone haywire. First, the on button won't stay on--the machine starts, but as soon as I let go the button, it stops. When I duct-taped it to stay on, it ran,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | Kenmore Dryers
Dryer won't heat. I need to check the thermal
need model number,if filter is on top,pull it out and take out two screws.get staight blade screw driver and put it in seam between the top of dryer and the cabinet and pop up on left and right side,{there are two clips holding the top on,one on the right the other on left side}, unplug door switch wires on right side and you'll see two 5/16 screws one on left and other on right around 4 inches down from the door switch,now grab top of front panel and pull up,there are two clips on bottom of cabinet that panel clips into,you'll see the fuse on the top of blower wheel housing,the fuse could also be located in the back of dryer too that's why you should send model number,hope this helps,while your in the dryer see if it needs to be cleaned out,that's what usually pops the fuse,check the lint filter duct,vac the inside of dryer and blow out the vent line,make sure the flapper is blowing open outside
Nov 07, 2009 | Dryers
My dryer does not heat up. I need to take panel off in order to replace. How do i do that?
Nov 04, 2009 | Kenmore Dryers
Push to start switch only works when held in.
Hi, THe control panel has an end cap that needs to be popped off. Just pull the end cap from the top and it should release. Then you will find a screw on each end that needs to be removed. Now the control panel will raise up and rest on the hinges.
This switch should not have an effect on heating.
Remove the front lower front panel and you can test the heating element. Check voltage to the element and you should get 240V. If there is now voltage, check each of the thermostats and the fuse for continuity. If the thermostats or fuse have no continuity, replace it.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 28, 2009 | Kenmore 659 Electric Dryer
Go thru the back to access the push to start via 1/4 inch screws. More than likely the push to start isnt the problem with the heat issue. i would lean towards the motor relay and the heater relays that are on this unit
May 27, 2009 | Kenmore 659 Electric Dryer
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
GLER642A dryer heating element
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Oct 10, 2008 | Frigidaire GLER642A Electric Dryer
My dryer had a power surge and kicked out my circuit breakers out twice. My light in my dryer went out. The light is located on the top of the opening of the dryer. I replaced it with a new bulb, but it...
depending on your dryer make and model, you may have a thermal limiter or a high temp fuse that went out. Also, you may need to look into new thermostat for it. If I had the make and model of the dryer, I'd be able to be more specific.
Mar 16, 2008 | Dryers
Need to Reset Fuse
It is possible that there is a wire touching when the dryer vibrates while running. The dryer top on some models opens by inserting a screwdriver or other thin object into the seam between the dryer to and the front of the dryer. It will hinge open. There is a door switch with wires running to it. Sometimes these wires rub on the drum causing a short. Also check for other wires that may be touching inside of the back of the dryer. Your heating element could be going bad or there could be a loose connection with the wires going to the element. Also some models will trip the circuit breaker if a load is really wet. Check to see if your washing machine is not getting enough water out of the clothes.
Feb 04, 2008 | Kenmore 64852 Electric Dryer
Kenmore 63942 Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
