Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Freezer/coldroom not freezing
Why is it that my commercial coldroom/freezer will not freeze to required temprature (-10C) and also why is the reurn line iced up from evaporator to compressor?
Solved, thanks
Posted on Nov 23, 2008
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Freezer too cold turned control in fridge down to 1 waited a day cant lower freezer temprature
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 19, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
I hooked a used unit up turned it on and got 3 beep any answers
this indicates that the backup freeze timer terminated the freeze cycle. Stayed in freeze cycle 60 minutes. Causes can be: stuck float switch, water valve leaking incoming water, and the more extreme can be hot gas valve leaking, txv not feed properly, low refrigerant charge, or bad compressor. Usually one of the first 2 items are the root cause.
Aug 21, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I left my refrigerator on during the winter months while I went to florida our heat had been turned off the freezer defrosted and all the food thawed out but beofre i returned it had all frozen again and...
as freezers are designed to operate from 10c to 35c,if the ambient temperature drops way below operating limits instead of freezing,the gas is actually warmer than outside and it will defrost rather than completely freeze solid.as soon as the lower limit (10c)is reached it will freeze again,unfortunately all the food is bad/unfit for humans/animals.although our local foxes love any food we put out.
May 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True commercial freezer
The ice could be preventing the freezer from freezing properly, try defrosting the unit. if this does not help then this could indicate a more serious problem like a bad temp sensor or refrigerant leak.
Apr 27, 2007 | True 52 cu. ft. / 1472 liter Commercial...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
102 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
