Question about Gateway GM4019E PC Desktop
My GM4019E does not have the color red anymore.
My PC does not have the color red. I purchased a new monitor and used the new analog cable when I installed it but had the same results. I have tried to adjust the settings on the PC and monitor still no red.
  • 56 Answers
Try another video card.
Posted on Nov 22, 2008
Please expert help me, my lenovo l192p have problem when i used analog port, it's look more red color, look dark red on dos. but it's good when i used digital port, dos look black.
Either the video cable or connector is loose or faulty. Try inserting the connrctors again and tighten the locking screws firmly and try a different video cable.
If none of this works then use the DVI ports on the monitor and video card.
Aug 24, 2011 | Lenovo ThinkVision L192P (Black) 19 inch...
I want color code of vga cable beetween monitor's board to 15 p connector
The best link I can find is here. However, not every manufacturer uses the same color code except the 3 main analog color cables Red, Green and Blue. Hope this helps.
Thank you for using fixya.com
Apr 11, 2011 | Computers & Internet
My viewsonic 19 inches lcd monitor screen displays full pink colour..it happens for sometime and becomes normal alternatively...
If you are using a VGA cable (analog, rather than a digital DVI) you can try replacing the cable. sometime some of the lines will break in the cable causing it to lose some color channels. Try tightening the cable connections on both the monitor (if it is removable) and the PC.
If that is not the cause, your backlight could be worn out. Cold cathode tubes run more pinkish red the older they get. Once they warm up they may return to a more normal color temperature.
Jan 07, 2011 | ViewSonic VA1912w 19" LCD Monitor
No red color red is black pink i sblue
E-Machine tech support are the same as Gateway Support. their answer to to reload always. sounds like a trouble video card or Monitor. try plugging in a different monitor and see if you have the same result. Make sure to check the pins on the video cable to verify none are bent. if you get the same results. you have a bad video in the computer. If it is, I believe that the video is actually integrated into the mother board, you can purchase a new video card and plug it in, that will automatically disable the onboard video.
Apr 03, 2010 | E-Machines eMachines Desktop PC
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My monitor is getting red color is there any solution
Hello !
Well, there is a problem with either your monitor, VGA cable or video card.
If you wiggle the VGA cable (the cable connected from your monitor to computer) and the color changes, the VGA cable is faulty.
Either connect your monitor to a different computer or connect a different monitor to your computer to see the results.
If your monitor works on another computer, your video card is faulty. If a different monitor works on your computer, then your monitor is faulty.
Hope this helps.
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
HDTV as pc monitor-no digital signal
Try different Resolutions/DPI and Refressh rates the other possibility is settings on the monitor check the manual of the monitor for use with the pc as in resolution etc.
Newer monitors oftem change there own settings to best suit themselves or act differently if forced to use different settings.
The returning to 16bit seems odd though only other suggestion is trying updated video card drivers from the vendors site.
Mar 18, 2009 | Computers & Internet
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Dell Flat Screen 19"
it sound like you eather need a new video card or there is something wrong with your moniter.
thanks
hope this help you
Aug 18, 2008 | Dell Dimension 4600 PC Desktop
Gateway GM4019E PC Desktop Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
