Question about Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
  • 2 more comments
  • genejacobsen Nov 23, 2008
    I gave up and left it on with it wall mounted. It fit. I'd stil like to take it off though!
  • Anonymous Dec 06, 2008
    We have the smae problem on getting the base off.
  • Anonymous Dec 23, 2008
    base did not come off when screws were removed. any tricks to removing the base?
  • Anonymous Feb 07, 2009
    I can't remove the stand from the 26" proscan lcd
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Posted on Feb 23, 2009
Two screws on bottom and the two screws above them..slide out base.
Posted on Dec 06, 2008
Amen to the solutions above.
Posted on Aug 19, 2009
This worked. We were ready to cut off the base but I gave it one more try. I ended up removing the 6 screws on the back (maybe I did not need to remove all 6, but I was pretty frustrated by this time) and the base slid right out (I also had the television resting flat on the sofa, screen facing down.) Thanks for the advice.
Posted on Jan 24, 2009
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Removing the stand from a Proscan TV
Remove 4 screws on the bottom.
Apr 01, 2009 | Televison & Video
I just mounted my proscan on the wall and can't figues out how to take off the stand
You probably have this figured out by now, but here's how I resolved it:
There are two holes marked with arrows, just above the stand, near the bottom of the set. Remove those. Next, roughly in line but slightly wider are two more phillips head screws. Remove those as well. The stand should slide out easily. Do what you want with the screws, but in case you have a future need for the stand, I jusyt put them back in the holes they came from
Mar 06, 2009 | Proscan 32LB30QD 32 in. LCD TV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote for tv
If your TV model number is 26LB30QD, it's $32.12 at remotes.com
Rate me if I answered correctly
Feb 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
688 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
