Question about Emerson HDC411 Humidifier
How do I install new filters in the emerson humidair hdc411 humid
Lost book. which direction do the beads face
MA-12010 comes on but will not stay on
my regservo need to active plz help me for activation code
Dec 29, 2013 | Emerson Humidifiers
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
No increase in humidity after installing whole house humidifier
have you checked the damper ? is the motor running the right direction ? have you increased the water supply to it ? you need to be sure that it is coming on only when you have a call for heat, normally your humidistat should be installed near the return, or on the return duct, for proper sensing, you could try holding a pan of steaming water, placing the stat above it, not to close, to see if the stat shuts off the hum, a little trick, that way you will know if the stat works ok, hope these helped, thanks for the question, mr.grzz
Jan 22, 2009 | Honeywell HE220A1019 Whole House...
Can't access to a website
try using mozilla fire fox
Dec 13, 2008 | Emerson HDC411 Humidifier
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
New filter
I have been unable to find your manual.
But, on Emerson's own site they have this posted:
If you cannot locate your model in the available download manuals, please contact customersupport@rgccanada.com
I would contact them and ask for a manual.
Good Luck.
Dec 20, 2007 | Emerson HDC12 Humidifier
Temp
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Emerson HDC411 Humidifier Logo
88 people viewed this question
Top Emerson Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you an Emerson Humidifier Expert? Answer questions, earn points and help others
