Question about Polaroid DVP-1000
Picture rolling vertically
I have had my dvd player for 2 yrs now, never had a problem until recently. In the midst of a movie, all of a sudden the picture started to roll vertically. Figuring it was probably the dvd, we inserted different dvd, same problem. When you first time dvd on, and it is on screensaver, it tolls then also, letting me know it's the player and not the dvd itself. Any suggestions?
  • soberami Apr 26, 2008
    Yes, I have the same problem. What is the solution?
3 Suggested Answers
  • 197 Answers
SOURCE: DVD player wnt read DVD's
bad dvd mech
Posted on Jun 07, 2009
hsips
  • 43 Answers
SOURCE: my polaroid tv screen is green and the picture is rolling
@ budmrtn, seems like it is always the cap problem in your opinion
Posted on Nov 23, 2009
Picture roll, loss of vertical sync.
I opened the cover, found nothing smoked or loose, no tweaks available, in short there was nothing I could do without diagnostic gear. All other sources in my system were fine, so simple substitution confirmed the problem was output of Teac dvd player. Taking it to a repair shop would be $50 up front for fix-or-not... So, I went to Walmart and replaced it with a Sony DVD player for about $40. Regret loosing the look of matching components with my Teac receiver, cassette player but it's job is to play movies. Fixtya!
Jan 04, 2010 | Teac DV-3000 DVD Player
Little white boxes rolling through picture
this is a problem with the mother board replace the mother board and then the problem will be solved
Mar 07, 2009 | Philips DVP642 DVD Player
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Picture keeps rolling
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Oct 03, 2005 | Panasonic DVD-F87 Multi-disc DVD Player
Polaroid DVP-1000 Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
