Hello, My unit above "apparently" does not decode 5.1 surround any longer. 3.2 is indicated on the screen each time the surround mode is activated. The problem seems to have appeared after a DirectTV installer hooked the Direct DVR system up. and about the same time frame, we sustained several power outages/surges.
I'm happy that I have the surround mode at all...however I've been told the problem is not unusual and is reprograming problem.
Can anyone suggest a remedy?
Thanks.
BigGeorge
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
I have a similar problem that happened after I hooked up my receiver with my HDTV and BlueRay player and after I had Direct TV installed. I am thinking it has something to do with the way I hooked things up different than before. I have the HDMI running from BlueRay and DTV to my HDTV and then an optical audio out cable to my receiver. Once I did this, i do not get the blue light (decoding) on the receiver like I used to get. This was the only way I could figure out how to hook up two audio outs when the receiver only had one input. The DVD's used to play 5.1 now they saw 3/2 and it doesn't seem like the true surround sound effect. Anyone have a clue?
