Daewoo Washer Error E8
I bought Daewoo Washing Machine Model DWD-F1013'S a few weeks back. It is showing an error (E8) on start-up & stops. Please help & oblige.
  • 2 more comments
  • badio4life Dec 05, 2008
    manual for daewoo washing machine dwd f1013
  • charlotteH Mar 12, 2009
    Same problem but with model DWDE1211W
  • Anonymous Apr 19, 2009
    I also have a Daewoo Washing Machine DWD F1013S that won't drain. I have cleaned the pump filter several times but it still wont't drain. This washer was bought new and only 3 weeks old in my house.
  • newasaas Jan 28, 2018
    E8 is a motor Problem, Check the motor transistor
  • Washing Mach... Master
  • 19,396 Answers
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
  • grant weatherall Mar 03, 2012
    where is the sensor located
    New Friend:
  • 3 Answers
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
Posted on Dec 05, 2012
  • 3 more comments
  • Bruno Ribeiro Jul 02, 2013
    Hi, thanks for the solution. I removed the 4 screws olding the controal board, but do not want to push too hard and the board does not pull out. What procedure should I have to remove the card safely? thank you very much
  • sonny tee Jul 31, 2013
    Thanks rrromzes, this saved my washing machine. My symtoms were E8, intermittent drum spin, and intermittent water inlet. All seems to work now after fixing solder joints.
    Hi bruno, it is not easy removing the board as it is covered in silicon/rubber all around. How i got it out was scrape the edges with a flat screw driver cutting the rubber then using 2 flat screw drivers i would dig under the board from the edges concentrating on the clips that hold the board down and lift if up trying to take the board with the back rubber in one piece if possible. My sitiuation was diy or trash so i had nothing to loose.
  • sonny tee Sep 15, 2013
    Sorry, i'd like to update with the solder fix. The problem came back shortly afterwards and i managed to fix it again by using an air compressor to spray the carbon brushes on the motor underneath the washer. Seems to have fixed it. Have put it through about 5 cycles now without a problem. I'm now putting it down to dirty carbon bushes. Hope that helps.
  • Benon Webare
    Benon Webare Dec 05, 2016
    i have the same problem, was the motor brushes rather dirty, will try this tonight.
    New Friend:
thank you very much
Posted on Jul 02, 2013
    New Friend:
The controller board can be removed by a flathead screwdriver and prying the board out if it's casing gently through the Silicone
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
I have a Daewoo DWD FD1233. It's brand new & 12 minutes before end of cycle it comes up with E8 as an error. The machine wont spin after that. What can i do? Lots of wet washing.
Jan 11, 2011 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Washing Machines Logo
12,624 people viewed this question
Top Washing Machines Experts
