Vertical black bar on screen
About a week ago the set came up with a vertical black bar.About three quaters from left to right.When I try to acces the menu options the black bar block most of the selections.Other than that the rest of the set works fine.Any kind of help would be appriciated thank you.
  • 1 more comment
  • John Martinez Nov 23, 2008
    You are asking me for the name and model.I could have sworn that I did but here it is again.Philips 42PF7320A/37.And this is the set with the black bar on the screen about 3/4 from left to right.
    You say the problem is convergence IC's.What are they and on my model 42PF7320A/37 where are they located.please let me know thanks.
    I received the pictures of the boards and connections.Which I am sure I can disconect and reconect even though you are nt telling how to do so.but I still do not know what Convergence IC's are.Can you supply me with pic's of at least one that would look like on my Philips 42PF7320A/37 thanks.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
It is the problem with convergence IC's. Replace the IC's it will be solved. R u connected with any DVD player using hdmi. Because these problem also with component connection. Check the connections of the player and also check the cables.
Thanks
Good Luck
Posted on Nov 23, 2008
    Genius:
  • 1,550 Answers
You need to provide brand and model number of your tv ?
It is due to power supply problem .
  • SAM ANDERSON Nov 24, 2008
    You need to buy two Stk392 convergence ic.
    You might have small feedback resistors burned but most of the time . You also may need the service
    manual to do touch up alignment in the service menu as you should
    never attempt any service manual alignments without a service Manual.
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Our Vizeo P42 purchased in July 2005 has had a red vertical bar on the left side for about two months. About a week ago it developed vertical lines across the left half of the screen with no picture...
sadly no.
either your panel has been hit and damaged or the panel itself is failing.
without some sort of warranty coverage, your repair cost would exceed the price of replacement.
Apr 12, 2011 | Vizio P42HD Television
2 Vertical lines on screen
It's either one of these things is dying:
Your Screen, or
Your video card
You can find out which by hooking your computer up to an external monitor, and if the lines appear on it, then it's your video card. If not, then it's your screen dying. And so you can either get a new screen, or a new computer.
Oct 02, 2009 | Compaq Presario M2000 Notebook
Green vertical bar on right side of plasma TV screen
You could have one of three problems. One is really expensing to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went back. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
May 25, 2009 | Panasonic Televison & Video
Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
May 19, 2009 | Dell Latitude D800 Notebook
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
