Dell OptiPlex 330 Desktop Desktop Computer  Logo
PETER Posted on May 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO ETHERNET DRIVERS - Dell OptiPlex 330 Desktop Desktop Computer
Shawn DuRee
Level 3:
  • Master 356 Answers
  • Posted on May 16, 2012
Shawn DuRee
Master
Level 3:
Answers
356
Questions
Helped
131923
Points
1300
Go to dell.com on another computer and put in the service tag for the computer you need Ethernet drivers for, copy them to a USB drive and then take them to the PC without the drivers and install them from the USB drive.
Ethernet drivers
this is the official site which allows you to download ethernet drivers for this model.
intel ethernet drivers and applications thinkcentre a30 a50 a50p m50 m50e...
3helpful
2answers
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
HP Compac dc 7100 mother board ethernet dirvers
click on the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=402165&prodSeriesId=402163&swLang=8&taskId=135&swEnvOID=1093
and then download the ethernet drivers for all operating system by clicking on download button listed next to
Broadcom NetXtreme Gigabit Drivers for Multiple Operating Systems
and then depending on the operating system, install the drivers and restart the system and then check the device manager
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
1helpful
Reloaded Windows XP on computer but apparently lost the ethernet drivers. Downloaded drivers but Wizard cannot find them. I know where they are but Wizard won;t let me select the files, Help!
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Ethernet+Components&ProductLine=Ethernet+Controllers&ProductProduct=Intel%c2%ae+82573L+Gigabit+Ethernet+Controller
http://download.cnet.com/PCI-Ethernet-Drivers-version-A01/3000-2112_4-109142.html
Hope this helps.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
4helpful
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
I recently had my hp pavillion dv 2000 with windows 2000 crash and it has been repaired but I am unable to connect to the internet. Turns out after a check I am missing my Ethernet card what can i do...
I the Ethernet card removed complete from your system or you mean to say your system do not detect your Ethernet card.
If the system do not detect your Ethernet card, then it is more of drivers related issues.
Re-install the drivers of your Ethernet card and try to connect.
This should solve your issue.
If there is no Ethernet card in laptop. Then, get one, install drivers for the same.. and try to connect. It will work.
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
3helpful
Ethernet Network controller
use driver updating software ie driver magician. it scans ur outdated drivers and automatically downloads drivers that r compatible for your computer.............
1helpful
Ethernet controller problem
go to device drivers and update the Ethernet drivers
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
