Question about Leica DISTO A5 Rangefinder
Screen is black but pointer is still lit
I turned it on as usual and there is nothing on the screen - it still beeps and you can see the pointer but nothing else - I've dropped it several times and just replaced the batteries with fresh ones but nothing - is it dead or is it fixable?
  • Anonymous Mar 17, 2009
    I have the same problem. Did you get yours resolved? Anyone with a possible solution?
Yes. I know exactly how to fix this because I had the same problem. Most likely what happened was the ribbon that attaches your screen to the motherboard has gotten loose or fallen off. All you need to do is remove the small screw (the only screw) on the back near where you remove the batteries. Then pop off the top rubber part on the front. Now you can pull the entire center piece out from the plastic case and you will see two ribbons. Make sure each one is secure to the motherboard. Put everything back in the casing, put the screw back in and it should work. It worked for me.
Posted on Jun 23, 2009
I also had the same problem. The black plastic ribbon appeared to be connected to the white plastic connector on the motherboard but it was actually just resting against it. It had slipped out. It took me a while to realise it was loose so followed the tips and wiggled it back in with my wife's tweezers! Thanks for the great help. I'd actually just bought it off eBay and was cursing the seller until I found your tip.
Posted on Oct 01, 2012
Bill W was right on the moneyh and just saved me $400. the ribbon(just the little plastic ribbon) had come dislodged fromt he white thing on the motherboard. I took a pair of large forceps and CAREFULLY wiggled it back in place....Thanks dude, I was so pissed.
Posted on Aug 07, 2009
Help! My Dell Inspiron Desktop (Windows 7) went into sleep mode, I shook the mouse to use it and got a black screen with just the mouse pointer. I powered down & back up, got the Dell screen and the...
My guide might help you, it's worth a try, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Sounds like a windows error though, some how the installation may have been corrupted. I suggest performing a virus scan on a test PC. An alternative is to take it in to a computer technician.
Thanking you
Happy testing
Nov 15, 2010 | Computers & Internet
Screen wont turn on
Propably your screen is damaged,
connect an external screen to see if its work.
if u can see your desktop in the external screen then its your screen thats damaged.
if u cant see your desktop in the external screen,
then its your graphics card adapter thats damaged.
Hope this was helpfull, Please vote!
May 14, 2010 | Toshiba Satellite L305D-S5895 Notebook
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 06, 2010 | ViewSonic VA1703wb Monitor
When I turn it on I get three beeps and nothing else
The 3 beeps are correct diagnosis for the screen problems.
reboot, keep tapping F8, till you get to
the start up screen ( black dos screen )
Try the last known good first at the top, let it roll.
If this fails, try safe mode, let it boot up, then try a system restore,
start,all progz, accessories,system tools,system restore, try go back in time.
If you cannot get into the "black" start up screen at all, your video card, has failed.
because you should get minimum of VGA graphics in safe mode.
if you do, then the video driver is corrupted and needs updating
Apr 24, 2009 | HP Pavilion dv6000z Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Wont turn on, bios beep code
Seems heat-related motherboard POST failure. Replace it.
May 25, 2008 | Sony VAIO PCV-V210P PC Desktop
Black screen
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
Leica DISTO A5 Rangefinder Logo
549 people viewed this question
Top Leica Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Leica Optic Expert? Answer questions, earn points and help others
