Question about Dishwashers
Main detergent compartment door does not open during wash.
I have a Kenmore Model 665, s/n 15522000, type 280-1 dishwasher and the main dish washing detergent compartment door, located above the pre-wash compartment on the inside of the main door does not open during the entire wash cycle.
The door is spring loaded and snaps open when I depress the catch manually.
I assume the force of the water is supposed to spring the catch and open the door during the wash but it's not working.
Please advise.
Thank you.
4 Suggested Answers
SOURCE: A Kenmore model 15522000 type 280-1 dishwasher will not drain
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Posted on Feb 05, 2010
  • 256 Answers
SOURCE: Dishwasher detergent clumps in pre-wash and main
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Posted on Feb 20, 2010
SOURCE: Whirlpool Model #DU890SWKQ0, Type 280-0,
I have a whirlpool dishwasher 280-0 that will not drain. What can I do?
Posted on Oct 24, 2010
The last month my kenmore 665 dishwasher will run its full cycle but the dishes don't look clean and there is dish detergent residue. So I bought glisten to clean the dishwasher and the wax pl
Obviously your heater is not working during the main wash cycle. This could be caused by a bad heating element of course, a bad thermostat, a bad controller, or even the door latch (1 of the 2 switches may be bad or may not be getting engaged when you close the door).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 11, 2014 | Kenmore Dishwashers
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
The main wash door doesnt open
switch to pre-measured tablets,and throw the tablet directly into the tank(d/w..)it works better that way anyways...most dispensers are very expensive also
Mar 03, 2010 | Dishwashers
Dishwasher detergent clumps in pre-wash and main wash compartments
Feb 20, 2010 | Maytag Dishwashers
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
Feb 13, 2010 | Bosch Dishwashers
SMEG SA 425 x Dishwasher - washing spinners stopped!
Can you hear the wash pump operating during the cycle? Pump could be faulty or blocked, or the pcb could be at fault
Jan 06, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher doesn't wash dishes right
The solenoid that opens the detergent door may have had water leak into it. Remove the inner panel from the main door, remove the solenoid mechanism and it's core. With the core out, clean the solenoid interior and the core surface with hot water. The core should fall out of the solenoid by gravity if it is clean. DO NOT OIL THE CORE OR SOLENOID. If there are signs of water entry to the solenoid, check the detergent dispenser seal for damage. Try using a tab type of detergent rather than liquid or powder. Make sure the release mechanism is clean as well. Hope this repairs your problem!
Dec 29, 2009 | Frigidaire FDB1050REM Dishwasher
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
