Question about York Yankees Bedding MLB Comforter
York furnace i have a york furnace model nr. n2ahd14a06c. For about 1 week the thermostat don't stop. I have a digital one and indicate heat on and after a few minutes aux.heat on. can you tell me if its correct that the furnace work all the time?I dont' have any manual for this furnace.Thank you very much for your help. Sincerely, Dana
  • bound4keywes Jan 02, 2009
    I have a two year old York furance and there is a red light on the furance and the thermostat is set on 67 degrees the furnace will come on and will shut off before the 67 degrees is met.
  • Allen Neal
    Allen Neal May 11, 2010
    is this just a furnace or a heat pump , sounds like a hp and in very cold weather will run long periods w/o shut down depending on outside temps what have these outside temps ranged ?
tborn6
  • 700 Answers
SOURCE: Heat pump wiring
yes i can , you need to hookup the r and the o together so that the reversing vvalvce is allways energized . so with that im mind send r,y,c,o to theout side unit. at the ahu you'll hook up the 5 wires for the furnace, r g w1 w2 com and at the thermostat r,w1,w2,y,g,com,o then you will be set (the o get hooked up to o and goes straight out side.
Posted on Dec 25, 2008
muttandjeff
  • 359 Answers
SOURCE: York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Posted on Jan 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Posted on Feb 25, 2009
  • 12 Answers
SOURCE: York Heat Pump outdoor cutoff thermostat wiring.
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
Posted on Sep 17, 2009
Testimonial: "OK...that's what I thought but figured I would attempt it myself, if possible. I will call my local heat/ac guys to install the cutoff switch. Thanks!"
MNfisherman
  • 11896 Answers
SOURCE: york manuals how does hvac zone york heating and
You can get the manual at york.com
Posted on Oct 26, 2009
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
I have a york furnace model no G2FD024H17G it stopped blowing warm air, so I opened furnace and the error code is 4 red flashes, which indicates possible dirty air filter (among other things). The air...
Kill power to the unit. Replace the filter or clean it up real good. Then turn it back on after 30 minutes the board should reset.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2011 | Heating & Cooling
Furnace will run, put out heat, turn off and doesnt start again.
What is model # & serial # of this furnace, it may have a diagnosis led indicator light located on the control board, behind bottom door of furnace which will blink and tell you a fault code. Also check furnace filter, make sure its clean, check through out the house to see if all registers are open and not blocked by any objects, make sure cold air return grill is not blocked, the unit could be over heating and shutting off on high limit, good luck.
Feb 15, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace blowers continues to run after reaching temp
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
Jan 27, 2010 | Electric York / Paragon A-111-20 Heat...
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Dec 27, 2008 | York Yankees Bedding MLB Comforter
Heat pump wiring
Dec 03, 2008 | York Yankees Bedding MLB Comforter
York Yankees Bedding MLB Comforter Logo
476 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
