Question about Lands Phones
Cannot open back of verizon flip LG phone to take out battery
Pryed it open
Posted on Nov 23, 2008
What causes my and my spouse and our IPad have no service bars?
Are your cell phones also on Verizon? LG makes the phone, they are not the carrier. If they are on a different network, then you probably do not have good Verizon service where you are.
Jun 27, 2017 | LG Cell Phones
My phone froze when trying to delete my text messages, I took the battery out, waited for a minute, put it back in and now when I turn it on it just flashes the LG Logo. Nothing I've done has helped at...
The problem is that the phone just needs a moment to work to delete your messages. Put the battery in and turn on the device. Then just set it down and allow it to work. Give it about five minutes and it should be done!
May 02, 2011 | Cell Phones
I have a lg qualcomm 3g cdma simple flip open verizon mobile cell phone. When on it used to have a blinking red dot appear on the flip -same as the steady red light when charging. Now the blinking has...
well that might mean that that light is just out or if u drop ur cell the it will disconnect it.... it probably all good if it charges and all that....... its just the light thats messed up
Jan 08, 2011 | LG Cell Phones
Answer LG without flipping it open.
By default, it's set to "any key" which means when you press any key on the keypad, calls will be received. If it's then go to call settings and set the answer options to "any key" and save the settings.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Verizon Communications LG VX8350 Cell...
How do i unlock my boulder? I pressed the lock button and I don't have the unlock code
type in six zero's 000000 that is usually the generic number or try 999999
hope this helps also try this, take the back battery cover off your phone, leave battery in there, now turn your phone on, now take the battery out just barely enough to lose power, then tilt it right back in, some models will reset this way, also can unlock cell phone with a magnet. put the magnet near the top and top sides of the phone, if it is a flip phone, flip open first.
Nov 21, 2009 | Verizon Communications Cell Phones
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
this might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
May 28, 2009 | Verizon Communications LG VX8350 Cell...
Verizon LG vx9900 unlock codes
last four digits of your phone number. i just locked it and i tried that and it worked.
Feb 18, 2008 | LG enV VX9900 Cellular Phone
Cell phone sim card
All mobiles have a sim card and are normally located under the battery.
Take the back of your phone, remove the battery and it should be there. Sim cards are normally a small oblong piece of plastic with a corner cut off. The flip side of one will have a metal strip, which is your sim memory. Don't damamge this side of the sim otherwise your card will be useless.
Hope this helps?
Dec 29, 2007 | LG VX8300 Cellular Phone
My cell randomly shut off, and now the only thing it does is stay on the Verizon logo...
Try removing the battery from the phone overnight (remove also the memory card if you are using one) and then on the following day put the battery back in (don't put the memory card back in - if using one) in and try to turn it on. If this doesn't help then the phone requires a flashing of the firmware (from your mobile operator). Good luck!
Dec 13, 2007 | LG Chocolate Clamshell VX8600 Cellular...
Lands Phones Logo
24 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
