Question about Hasbro I-DOG AMP'D
When I went to turn my idog on it made these weird sounds
It also wouldn't tap his foot or move it's head .I tried giving it different batteries but it still had the exact same problem,HELP
  • 3 more comments
  • BoomShine Dec 23, 2008
    it makes this wierd vibrating sound...i press the tail up and it stops but only for a few seconds..
  • smaguffey72 Feb 01, 2009
    My daughters Idog has a similar problem. It plays music but makes a scratchy noise as well. The foot will not tap either. I've changed the batteries, turned it on and off at the nose but the intro music doesn't start, just alot of scratchy noise. Can it still be exchanged after a year? It was a Christmas gift last year...
  • Anonymous Mar 23, 2009
    My idog will do everything except dance. How do I get the dog to dance?
  • ljsnider_1 Apr 01, 2009
    makes wierd noises, tail, foot and head don't move.
  • gigikat Oct 26, 2012
    me to! my idog makes the same sounds but dosent move
    Problem Solver:
  • 5 Answers
Check underside near front legs and switch the "on". Volume is tail front to back to change. Push the nose and rub the face and also try switching the connection cord end to end to the MP3 player or Ipod.
Posted on Dec 28, 2008
Cannot turn but has ignition light on.
Battery terminals OK??? Battery OK??? Check for the fuse and circuit breaker for iginition.
Mar 21, 2014 | Toyota RAV4 Cars & Trucks
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
I can't get my techpet to wirk
Instructions
    • 1 Check that the iDog is powered on if it doesn't respond to your commands. Press its nose to activate the toy.
    • 2 Verify that the iDog has fresh batteries installed if the dog doesn't turn on. Use a Phillips screwdriver to open the dog's battery compartment, located on the its right back leg. Insert two new AA-sized batteries according to the "+" and "-" symbols listed in the compartment.
    • 3 Inspect the iDog's connection to your iPod if it doesn't move and dance to your iPod's music. Plug the iDog's connector cable into your iPod. The cable end labeled "B" gets inserted into the headphone jack on your iPod. The opposite end goes into the front left leg of the iDog.
    • 4 Make sure your iPod is powered on if the toy is connected to the media player and is turned on, but not moving to the music. Your iPod may need recharged by connecting it to a computer with its included USB cable.
    • 5 Reset the iDog if it continually freezes or stops moving in the middle of a dance. Use the tip of a pen, paper clip or similar thin object to press the reset button located on the bottom of the toy's head.
Jan 20, 2013 | Toys
Today I went to turn on my car and it didn't crank
make sure the starter is tight and your battery cables are clean and tight if automatic try putting it in neutral if it starts you may have a bad neutral safety switch if it is a stick try push starting if it starts you may have a bad clutch switch also check for a starter relay if u have one try swaping with horn relay and see if it starts
Mar 25, 2012 | 1993 Ford Probe
My idog will not turn on. i just replaced the bat...
Try plugging in your iPod and playing music worked for me and/or put new batteries in it but do NOT press reset
May 20, 2010 | Hasbro I-DOG AMP'D
Idog
Please take a look at this PDF file it has the instruction included for the I-dog. http://www.hasbro.com/common/instruct/I_Dog.pdf. I hope this helps please let me know and I will try to find something else for you.
Thank you
May 05, 2010 | Hasbro iDog Electronic Pet Dog
I got my iDog from a friend. I took the batteries out and there was a weird white powder. I put new energizer batteries in and it won't turn on. What do I do?
It sounds like the battery leaked. First, disolve some baking soda in water and carefully and as dry as possible, wipe out as much or all of the residue. Attempt after a few hours of drying to re-insert fresh new batteries and see if it turns on. If not, I would save the leaked batteries in a baggie and contact the battery manufacturer via carrier mail and explain that the batteries leaked in your device and it will no longer work and you would appreciate either a repair or replace. Most times if you have the bad batteries and mail them in also, they will either reimburse you for the product if they are not able to repair it. I know this has worked for energizer and rayovac batteries. Be civil and professional in the letter and I bet you get some resolution. Good Luck and hope this works for you. Actually, before cleaning the product, you should probably contact the battery company first if possible so the proof is still in the iDog. Good luck
Dave
Aug 09, 2009 | Hasbro iDog Electronic Pet Dog
How to charge a idog
You don't "Charge" iDog AMP'D, you change the battery pack located under it's hind feet. When your iDog does the intro when you turn it on every five seconds, that means it's time for some new batteries!
Jun 28, 2009 | Hasbro I-DOG AMP'D
Idog keeps dying!
The idog should not do that and i suggest returning it or exchanging it for another one.
Dec 31, 2008 | Hasbro I-DOG AMP'D
Hasbro I-DOG AMP'D Logo
344 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
