Question about Oreck XL2200 Bagged Upright Vacuum
Not picking up dirt.
I replaced the 1/2 filled bag in my XL 2200 HH, and checked the main pipe in the handle. Turned the unit on, tried to vaccuum, and the dirt does not get picked up. The roller underneath spins and sends the dirt back out. Nothing goes into the bag.
  • 56 Answers
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Posted on Nov 22, 2008
I cannot keep the bag attached to the handle inside the cover on my Oreck XL Vaccuum. When it comes off dust blows out into the cover instead of the bag which makes it very hard to unzip the cover.
there should be a spring ring that slides up over the bag on the handle if thats missing try and use a couple of heavy duty rubber bands. however i do suggest you order the correct part.
Feb 13, 2013 | Oreck XL Ultra Bagged Upright Vacuum
2200 watt dirt devil
If it has a belt it may be stretched out and need replaced
Dec 02, 2017 | Vacuums
My Oreck XL vacuum does not have enough suction to pick up dirt. Any suggestions to remedy this problem? The belt is strong, the bag is not full, and there do not seem to be any obstructions.
Turn the machine on and be sure the bag expands quickly and fully like a balloon. If the bag does not fill with air, or is soft, there is probably an obstruction inside the handle tube or fan housing. Disassemble the handle to check for blockage, or remove the bottom plate to check the inlet to the motor fan.
Jan 19, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My bag is brand new and is not filling up with air and picking up dirt. Oreck xl
There may be a clog in the handle. The handle in Oreck acts like a hose to connect the floor part to the bag part. They are designed to come apart for this very reason. Inspect yours to find the diretions for clearing. No air in the bag is a dead giveaway in this case.
Thanks for posting at
Dec 13, 2009 | Vacuums
No Suction
Your Power head is blocked with hair or dirt,,or the hose which connects the Upright with the power head is blocked.
Try taking a steel coat hanger apart (straighten it out) and then push it into the pickup hose to remove blockage.
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
You'll have to unpick or slide up the rubber rings on the back of the handle at the bottom where the rear of the bag is. Unclip the bag so that it moves freely, slide up the rubber rings and you'll find a series of pop locks. Push these in to take out the main dust spine pipe - also remove the power cord at the top of the handle to release the handle. In the middle of the spine there is one screw that bonds the top handle part to the spine, unscrew this so that you can split the two parts up and check for clogs. Also check the main dust channel that leads to the bag - it is notorious for clogging because of its relatively small dust channel.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
267 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
