AKAI PDP4249G Losing Picture and Sound
My tv recently started acting up. I will be watching tv just fine, and all of a sudden the picture and sound goes out, and the speakers make a strange crackling type noise. The tv then proceeds to Auto search for signal, but in never does find any signal. In order for the tv to work again, I have to leave the tv turned off for a few hours before it works again, but then it just repeats the cycle of losing picture and sound again after about 10 minutes or so of viewing (sometimes it may take longer than 10 minutes, but it will eventually reproduce the problem).
Anyone have any ideas???
  • bouchigo Nov 22, 2008
    I would also like to add, that sometimes when I press Brightness, Freeze, and Menu in rapid succession, the picture comes back, but there is still no sound.
    Top Expert:
  • Televison & ... Master
  • 75,767 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 15, 2017
5 Suggested Answers
lukster
  • 217 Answers
SOURCE: akai pdp4249g plasma monitor
Do you have any kind of anteanna? Go into the user menu and choose channel, then choose air or cable then do a auto programming this will pull in all the channels that is available and save them to the memory
Posted on Apr 16, 2007
TVtechmaniac
  • 140 Answers
SOURCE: losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Posted on Sep 28, 2007
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
  • 55 Answers
SOURCE: TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
Posted on Jul 14, 2009
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
My Flat screen model no. LCT2721ad will not turn on.
I have a vizio 42 " LCD TV, model #VX42L, I was watching tv last nite all
of a sudden there was not sound or picture, I could not turn the tv off, but I could turn the dvr off. Still no picture or sound.
Sep 22, 2009 | Akai Televison & Video
With no picture but only sound on my Akai PDP 4294
Try replacing the Y-sustain board. Might have to replace buffers attached to it too. Have you had it diagnosed? My picture went out and I replaced the power supply board. Worked for 2 weeks then acted up again. Got a different power supply board. Same thing 2 weeks later. Was told it now was a bad Y-sustain board. Replaced y-sustain board. Worked OK for about 2 hours then started having picture issues. Not the same issues before power supply or y-sustain problem. Was told that you might have to replace buffers attached to y-sustain when you replace y-sustain. Tired of dealing with it and only watch a couple hours a day, so I don't always have the problem unless I watch the TV for a long time. Will eventually replace buffers to see if that works. I would definitely find a place that gives free estimates or close to free to get a technician diagnosis. Then you can decide if you are able to do the work yourself.
Jun 06, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sound works no picture
t.v sounds comes on picture not working can watch pip . sometimes when you turn the t.v the timer light in front flashes can u help
Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
No picture do have sound
i think you have a blown tube.if theres no pic but sound youve got a blown tube
Nov 03, 2008 | Akai PT5598HD 55" Rear Projection...
AKAI PT5492S
make sure it's not muted. you can also change from lift to right speakers. you may have burned up the audio driver amp.
Apr 22, 2008 | Akai PT5492S 54" Rear Projection...
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sound but no picture
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Nov 17, 2006 | Akai LCT2060 Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
