Question about ASUS K8V-MX Motherboard
Smps transistors failed
I used p4 mother board. i have been used mercury smps with 400wolts from 2 years. recently when i swithched on cpu backside power button suddenly there was a flash fire comes and totally smps dead . no beep sounds comes. i removed the power sockets and plugings of smps from motherboard. when i opend smps a fuze was damaged. i replaced the fuze and rearranged a new fuze in smps with the help of electrocian. again i check smps by put power plug with back side of smps. then there was a huge fire crash happend. the electrician told me that the transistors of smps were damaged. why it happend. i used UPS also. i am using same ups to other system and it works fine. but why this system smps was damaged. please tell me. amd also tell me what is cost of the new smps in the market.send yours answers to my email id: shaliguntur@yahoo.com
    Problem Solver:
  • 9 Answers
Try to chech out the most suspected component such as capacitor, diods transistor and resistors that went bad. Unless U have 2 change the whole SMPS.
Posted on Sep 18, 2012
    President:
  • 2,992 Answers
It is difficult (or impossible) to tell exactly what caused the transistors to go bad. Sometimes they just fail because they were a little weak, or other parts went bad first and caused the transistors to be damaged. Parts get weaker and values change over time and with use, and failures can happen. The UPS can't stop damage to the power supply if some part inside the supply goes bad, but it is still good to have one. New 450 to 500 watt power supplies can be purchased for $30 to $50 (or more).
Posted on Nov 23, 2008
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
No beep i had 915glvg intel mother board i had recently issued the problem no beep and no display and under cpu it is heating... ram ok smps ok mointor ok cpu ok
Hi there
It could be a memory issue, try different memory, if you still get nothing the bios is probably corrupt rendering the board useless.
Good luck and thanks for using Fixya!!
Feb 11, 2009 | Intel Motherboard
I want to upgrade cpu on mother board p4p800
*********** board supports upto 3.2 GHz+ P4 CPU
Dec 03, 2008 | ASUS P4P800-E Deluxe Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Msi 654e max atx mother board
If your manual states a max of 2.2GHZ then, take it as that, when your board was made the bios and bus speeds would be set at the maximum to run a 2.2GHZ, not a 3GHZ, also the heat sink and fan may not be enough to cool the processor. The only way that a 3GHZ would run was if you updated the bios and personally i would not recommend it. You would be better advised updating the board and processor as a package ot fitting more memory if the pc is not used for gaming or high end video editing.
Apr 19, 2007 | MSI 645E Max Motherboard
ASUS K8V-MX Motherboard Logo
300 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
