Question about Palm LifeDrive Handheld
Life-Drive will not power on.
When I plug the Lifedrive into an outlet, the battery light shows thats its charging, but, the darn thing still will not turn on. I dont know how to solve this as it is out of warrenty, and to say the least a rather irritating problem. Absolutely nothing has happened to it, as far as a drop or water damage. Its been taken well care of, and all of a sudden, it wont power on anymore... ANY help will be just that.
  • Anonymous Dec 29, 2007
    My lifedrive won't turn on. There is no power getting to it. Any ides?
I had the same problem this morning. I removed the battery as above with no result!! Touched the power switch again and got a momentary flash from the power light. A couple of GENTLE puffs of air around the switch and hey presto away it went. It seems likely that dust etc. can get through the edges of the switch and eventually hold the contact blades apart.
Posted on Aug 20, 2007
I don't know how much technical skill you have, but I had the same problem and the warrenty had expired. I thought it might be a battery problem. To make a long story short I unpluged the internal battery and pluged it back in and the system came on.
Posted on Jun 24, 2007
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Lifedrive won't start. Neither will it reset,
Unfortunetly that usually indicates the harddrive has failed on you. Try a power on hard reset. It is the same as the hard reset but the power need to be plugged in as well.
If you look there are several places that will replace the drive with either a new drive of a compact flash card. The card is the way to go as it increases battery life but is about 10x faster acessing stuff.
Dec 13, 2009 | Palm LifeDrive Mobile Manager Handheld
Inspiron runs on ac power but not battery
Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
Jul 20, 2009 | Dell Inspiron 1501 Notebook
When the lifedrive dies duo harddisk, there are
You have two options one is of course a replacement drive but the other is replacing the little hard drive with a flash disk. The flash drive is nothing more than a 4gb compact flash memory card that happens to use the same connector as the Hitachi hard drive. Of the two I'd go flash myself.
The flash disk is faster and uses far less power so your battery life can increase by quite a bit. I think it is something like 10% of the power. Next to the display this is the single biggest power item. I've heard of the useful battery life increasing anywhere from 3x to about 6x after doing this. You can get the drive or flash from several places online. These are the same CF cards as used in many cameras. Most also offer the installation service.
Here is a link to one place but do a few searches and compare prices etc. Just search for lifedrive, flash, drive or lifedrive hard drive replacement and you should get quite a few.
http://www.usedpdaparts.com/Lifedrive.html
Jul 12, 2009 | Palm LifeDrive Handheld
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
My Lifedrive wont turn on...
get a new charger..or return it..hopfully you got extended warranty. mine did the same and it took like 20 minutes just to have enough energy to restart.
Oct 21, 2007 | Palm LifeDrive Mobile Manager Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead Lifedrive
I im not mistaking this unit has a 1 year warrantee. I would contact the #v below to see how to get this back up and alive. Good luck 847-262-PALM
Apr 15, 2006 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Handheld Logo
125 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
